Icon/Badges reset and cannot be modified
The new firmware 54.10 broken edge driver´s Shelly and Tasmota.
Too all of my icons/badges are reset and I can’t change them anymore.
Any solution??
This update is being a setback in our lives… I have the same problem.
Hi, @cljara80, @Casa_Virtual_Automac, @Andreas_Roedl
I saw you mentioned you have issues with the icons and badges assigned to your devices.
Can you provide more details, please? I mean:
  1. Did this happen with all of your devices without considering driver, type, etc.?
  2. If the answer to 1 is yes, please select two devices, provide their names and mention which icon they had before and which one they have now
  3. Did you notice when this happened (date and time)?
  4. Which OS and version of the ST app are you using?
  5. Confirm the email account registered in the forum is the same one you use for SmartThings. If not, please share it with me over DM
  6. Enable support access to your account:
@cljara80, can you open a new topic here about your issues with Shelly and Tasmota drivers, please?
  1. Yes, all devices affected, regardless of driver, profile, execution location.
  2. Name: Ventilator
    Profile: power-energy-powerConsumption
    Original icon: fan
    Current icon: socket
    Profile: contact
    Original icon: door
    Current icon: contact
  3. 2024-09-27, between 2 am and 10 am GMT+2 - I know, it’s a huge timespan. I woke up this morning and the icons were reset to default.
  4. Android, 1.8.18.21
  5. Same email address
  6. Done
Ok, on the details of this device I see it specifies the Fan icon:
    "id": "main",
    "label": "main",
    "capabilities": [
    "categories": [
            "name": "SmartPlug",
            "categoryType": "manufacturer"
            "categoryType": "user"
    "icon": "oneui/oic.d.fan"
For this one, I see on its details it has the icon door:
    "id": "main",
    "label": "main",
    "capabilities": [
    "categories": [
            "name": "ContactSensor",
    "icon": "oneui/door"
Can you share a screenshot of how these devices appear in the app to include them in the report, please? It seems the app is ignoring the icon we can see in the API for some reason.
Thanks for the information, so, just to confirm, did you notice if it happened for the device called Badezimmerlüfter as well?
Same here. All icons reverted to the default icons I believe earlier today. And now there is no way to select alternative icons.
I am using Android 13 and 14 devices with app version 1.8.18.21.
Firmware is still 53.19.
This device’s icon was set to default before. Never changed it.
Older screenshot from before (devices Badezimmerlüfter on the lower left side):
After:
Same problem, all the icons I have chosen have reverted back to the original when the device/s were added. Also can’t change the icon at all, this option is not there any more. I’m using SAL Pixie switches that turn on an exhaust fan, I have choosena fan icon for this but it’s reverted to a switch icon now. Please fix this issue and add many more icons as it’s much easier to see the device among many using an icon. This issue happened at some point 27th September 2024
  2. These are some of them (they are almost all)
Original icon: bulb
Current icon: switch
Original icon: bulb
Original icon: bulb
Name: Luz meson cocina
Original icon: bulb
Current icon: outlet
Original icon: bulb
Name: Luz comedor plantas
Original icon: bulb
  1. 2024-09-26, maybe in the morning, maybe in the morning, I don’t know an exact time.
  2. Android, 1.8.18.21
  3. cljara1080@gmail.com Location “Casa”. My other two location (Casa Paute y Suite H Mata) are same
  4. Done (Location “Casa”)
My icon problem has been resolved this evening.
The problem seems to have been resolved thanks. Please add more icons they make it much easier to use the app.
Fixed.
Thank you, @nayelyz .
Good morning! I apologize for the delay, but I was away. The episodes happened in the morning on the same day as the report. All the icons were changed, fixed and could not be changed again. The interesting fact is that only the icons for the rooms, i.e. bedrooms, living rooms, etc., were changed. The icons for the scenes and tasks remained as they were in the programming. Today, after two days, the icons returned to normal, as they were before the problem.
Hi, everyone
Thank you for reporting this went back to normal. It seems the engineering team was already working on that because there were no updates in my report.
In case I get more information, I’ll let you know.
