Guys, if you are recycling the older remote or hub based on the integration, well make sure you are within the return period taking into consideration the time it will take the integration to work properly. Be warned. You will not be able to add the harmony hub to ST since harmony’s update and reupdates have rendered it useless. You will have to recycle and reboot your brain every single day! And freaking NO backlight on a 350$ dollars remote and horrible resolution on the touch screen on the remote…
From not so proud owner of harmony ultimate home.
