I was changing a variable in a Piston when it crashed and kicked me out to the main smartthings app page. Now if I go back to that Piston it gives a “unauthorized user” error and if I try to create a new Piston, gives me the same error. I can access my other pistons and every other Piston seems to be working.
Any ideas to fix? Tried rebuilding all pistons, reset token and pause and restart the broken Piston. Out of ideas.
It as a lil bit tricky to erase but on that same page at that top where it says “Installed Smartapps” and to the right there is an “Edit” link which will the exposed the “uninstall” option for each smartapp.
Was able to remove it that way. Was getting worried that I may have to erase CORE and start over and rebuild my pistons. Yikes!.
CoRE has gotten hosed up somehow on me & I’m not able to create new or modify existing pistons so I’m trying trying to remove multiple pistons using the IDE & start fresh When I try to uninstall, nothing happens & if I try to open a piston via Smart Apps it won’t open. Any suggestions on a fix?
Running CoRE v0.3.168.20161220
That did it - thx. Able to clean things up now & create new pistons
I guess I thought the latest version would have been available for me to update from the GitHub CoRE (master) repo.
