I have had problems with the summary tiles
On iOS, the app shows 96 devices in the list of devices in the offline panel. The APP on Android only shows 77 devices. On Android, several devices do not appear in the list to be added or removed in the panel settings. This is a horrible bug, it messes up the entire panel configuration, which would be a good function.
Is that with the same SmartThings user in both cases?
In the API this stuff appears to be user specific but the mechanisms involved are a mystery. The current values of a subset of the tiles can certainly be read from the API and reflect what I see in the Android app. The API also shows lists of unselected devices for each tile, which again reflect the completely broken Android app.
@higorchv Thanks for the tip
I made settings using my iPad. This fixed also Dashboard in Android App.
Apparently the problem is only with the Android App now.
Android App problems I had:
How did you do it? Here I can fix the panel on iOS, but on Android the panel does not change. On the contrary, after uninstalling and installing the SmartThings app, all the devices in the panel settings disappeared.
Selection list in Android App is not fixed, but selections that I made using iPad are operating.
Dashboard Mini Tile now show the correct temperature on Android App.
