The only way to update the temp/humidity is using the ST classic app and hitting the refresh button. In the new ST app I dont even see that option. I don’t see anything in IDE either. I’ve tried using a polling using the “simple device viewer” with no luck. Is it just that the device doesn’t support it???
Same problem here. No update unless I tap the device refresh button.
are you guys still having trouble with this?
