Hunter Douglas Power View Gen 1 & 2 Edge Driver
For anyone interested, I wrote this custom device handler for my Hunter Douglas Power View shades. It should work with shades that communicate with the 1st and 2nd generation PowerView hubs. I only have roller shades and bottom-up Applause & Duette type shades, so that is what I developed the driver for.
Note, the driver requires knowledge of the PowerView hub’s IP address, therefore it is prudent to assign it a fixed IP address on your network. It also requires the shadeID. This can be found by navigating to http://< hubIP >/api/shades on your browser of choice. Create one device for each of the shadeIDs you see at the top of the webpage, you can then use the jog function to identify which shade the shadeID belongs to and rename the device accordingly.
I’d like to thank TAustin whose published drivers I borrowed heavily from in generating this driver, as well as schwark for inspiring me to write my own driver for the PowerView generation of Hunter Douglas shades.
Hi, @maranhao!
A user mentioned he cannot enter to your channel invitation and I think it’s due to the link you shared.
For users to enter the invitation to your channel, you need to share the link generated when you create the invitation.
You should be able to see it using this CLI command:
smartthings edge:channels:invites
These are the headers of the table shown as the result:
Could you update the URL, please?
@nayelyz thanks for informing me of my oversight. I believe I have fixed the issue. Please let me know if the user still has issues accessing my driver.
Thank you, @maranhao!
@David2275, could you check if the new link shared in the first post works for you, please?
Yes it did. I also messaged the dev directly for some additional assistance. Thanks for your help!
To those individuals who may be interested, the source code for this driver can be found here. GitHub - maranhaoBruno/HD-Powerview-Gen1-2
Ok. So I think I have the edge drivers installed, but how do you actually get the shades added to Smartthings? How do you add/create the device? Do you create a custom device or something then assign the driver?
I figured it out. For those like me who didn’t know, you add the driver, and then in the ST app, you scan for devices. The device you added the driver for should get added. Then you can modify the driver settings as required to add the powerview hub IP and shade IDs.
@snrsuave Some individuals have run into issues getting the driver to control their shades. Can you confirm that you are able to open and close your shades, and what version SmartThings hub and PowerView hubs you have? Thanks!
Firstly, thanks for making this available and for your work. It kind of works. I have silhouette shades and the driver works to open (lift) and close the shades, but does not control the tilting of the vanes. Also, I have parkland wood blinds that are motorized and the driver does not work with these at all. The only thing the blind responds to is the jog command.
I could not control the shades. I have a Powerview Gen 1 hub, a ST Gen 2 hub and Silhouette shades. I know my hub IP is correct because I was able to pull a shade iD list from the hub.
James, I’m sorry the driver is not working for you. By any chance, are you able to jog the shades, but do nothing else? It seems to me that everyone experiencing issues is operating on a gen 1 PV hub, and though it is odd to me, this may be the issue.
Hello,
Thanks for the follow up. Jogging does not work either. Nothing seems to work from the testing I performed.
I have been using the johnvey integration for years without incident, until I accidentally deleted it last month.
I attached the API which I believe is for the Gen 1 hub. I ran some of the commands from a web browser, which I have included below. Maybe this will help.
http://192.168.1.222/api/shades returns:
{“shadeIds”:[1031,29438,24140,9790,23753],“shadeData”:[
{“id”:1031,“name”:“U2xpZGVy”,“roomId”:19103,“groupId”:62497,“order”:0,“type”:23,“batteryStrength”:171,“batteryStatus”:3},
{“id”:29438,“name”:“VHJhbnNvbSBSaWdodA==”,“roomId”:19103,“groupId”:62497,“order”:1,“type”:23,“batteryStrength”:166,“batteryStatus”:3, “positions”:{“position1”:1794,“posKind1”:3}},
{“id”:24140,“name”:“VHJhbnNvbSBMZWZ0”,“roomId”:19103,“groupId”:62497,“order”:2,“type”:23,“batteryStrength”:149,“batteryStatus”:3},
{“id”:9790,“name”:“VHJhbnNvbSBDZW50ZXI=”,“roomId”:19103,“groupId”:62497,“order”:3,“type”:23,“batteryStrength”:166,“batteryStatus”:3, “positions”:{“position1”:1436,“posKind1”:3}},
{“id”:23753,“name”:“U2l0dGluZyBBcmVh”,“roomId”:19103,“groupId”:62497,“order”:4,“type”:23,“batteryStrength”:170,“batteryStatus”:3, “positions”:{“position1”:1794,“posKind1”:3}}]}
http://192.168.1.222/api/scenes returns:
{“sceneIds”:[30096,22248,36455,29301,18247,50628],“sceneData”:[
{“id”:30096,“networkNumber”:3,“name”:“T3BlbiBTaGFkZXM=”,“roomId”:19103,“order”:0,“colorId”:9,“iconId”:96},
{“id”:22248,“networkNumber”:2,“name”:“Q2xvc2UgU2hhZGVz”,“roomId”:19103,“order”:1,“colorId”:10,“iconId”:97},
{“id”:36455,“networkNumber”:5,“name”:“T3BlbiBWYW5lcw==”,“roomId”:19103,“order”:2,“colorId”:5,“iconId”:95},
{“id”:29301,“networkNumber”:1,“name”:“Q2xvc2UgVmFuZXM=”,“roomId”:19103,“order”:3,“colorId”:4,“iconId”:66},
{“id”:18247,“networkNumber”:4,“name”:“V2ludGVyIE5pZ2h0cw==”,“roomId”:19103,“order”:4,“colorId”:15,“iconId”:19},
{“id”:50628,“networkNumber”:6,“name”:“R29vZCBNb3JuaW5nIFN1bnNoaW5l”,“roomId”:19103,“order”:5,“colorId”:12,“iconId”:12}]}
http://192.168.1.222/api/scenes?sceneId=50628 runs the scene and returns:
{"scene":{"shadeIds":[23753,9790,29438,24140,1031]}}
If you need me to do some testing, please let me know.
Thanks again!
James
(Attachment Powerview-Third-Party-API.pdf is missing)
*** First message bounced because of attached. Added link to API below ***
Hello,
Below is a link to the API which I believe is for the Gen 1 hub. I ran some of the commands from a web browser, which I have included below. Maybe this will help.
https://mynzws.co.nz/wp-content/uploads/2021/05/Powerview-Third-Party-API.pdf
Thanks again!
James
Hi, I also have the Jonhvey integration and strangely the shades that I had original linked to SmartThings before the Edge transition still show up and still work. And in ST site, I see Hunter Douglas PowerView as an Automation. I can click on it, see the PV IP address and link more shades and scenes. However hitting Done generates an error so no new shades or scenes are created in SmartThings. Did you also have the old implementation working post the Edge transition? I assume at some point, I will delete that Automation and the linked shades and scenes and start over the this new Edge driver? Appreciate the input. Juergen
I did not have the old Groovy based integration running post moving to my driver.
Hello,
Has anyone figured out the noted issue of not having the “jog” or any shade function work when implementing this edge driver? I also have a Gen1 hub and I can pull the shade information using the browser, but nothing works with the shades in ST. I am hoping there is a solution as this is the one function I miss most with the groovy shutdown. Can someone who has it working post a screenshot of the information they entered in settings. I want to be sure I have the formatting correct. Thank you.
Were you able to find a solution for the Gen 1 hub? I deleted my Groovy installation during troubleshooting and cannot reinstall it…
Hi maranhao,
Just curious if you were able to look into the Gen 1 hub and if the info below was any help.
James,
I haven’t and don’t plan to look into this issue. I’ve released the source code on my GitHub linked above. Feel free to trouble shoot it. I think there is an ever so slight change in the formatting of the HTTP POST messages that needs to be made for it to work with the Gen1 hubs.
-B
