This is a copy of the vera code to made it possible, if i’m reading it right it looks like a TCP socket connection. So while yes, it might be possible to make it happen… it won’t be easy as SmartThings doesn’t officially do TCP sockets.
-- Hunter Douglas Platinum bridge driver version 1.2 by Gengen
-- This software is distributed under the terms of the GNU General Public License 2.0
-- http://www.gnu.org/licenses/old-licenses/gpl-2.0.en.html
local PlatinumShade_PollStarted = false
local PlatinumShade_Connected = 0
local PlatinumShade_ConnectTime = nil
local socket = require("socket")
local http = require("socket.http")
local bit = require "bit"
local PlatinumShade_pollInterval = 180 -- 3 minutes
local PlatinumShade_Db = { rooms={}, shades={}, scenes={}, schedules={} }
local PlatinumShade_NeedSync = false
local PlatinumShade_Queue = {}
local PlatinumShade_WaitingFor = nil
local PlatinumShade_ActLevel = 0
local kUPD01 = 1
local KShadeActionPending = 2
local ANSI_RED = "\027[31m"
local ANSI_GREEN = "\027[32m"
local ANSI_YELLOW = "\027[33m"
local ANSI_BLUE = "\027[34m"
local ANSI_MAGENTA = "\027[35m"
local ANSI_CYAN = "\027[36m"
local ANSI_WHITE = "\027[37m"
local ANSI_RESET = "\027[0m"
-- All logging goes through this function.
-- Comment/uncomment the luup.log line to enable/disable verbose logging
function log(msg)
-- luup.log("Platinum Bridge: " .. msg)
end
-- A debugging function to output a complete LUA object heirarchically
function printTable(tab,prefix,hash)
local k,v,s,i, top, pref
if prefix == nil then
prefix = ""
end
if hash == nil then
top = true
hash = {}
else
top = false
end
if hash[tab] ~= nil then
log(prefix .. "recursive " .. hash[tab])
return
end
if type(tab) ~= "table" then
if type(tab) == "string" then
tab = tab:gsub("\t", "\\t")
tab = tab:gsub("\r", "\\r")
tab = tab:gsub("\n", "\\n")
end
log(prefix .. " (" .. type(tab) .. ") = " .. tostring(tab))
return
end
hash[tab] = prefix
if top then
log(prefix .. "{")
pref = prefix
prefix = prefix .. " "
end
for k,v in pairs(tab) do
if type(k) == "table" then
log(prefix .. "key-{")
printTable(k,prefix .. " ", hash);
s = " }: "
else
s = tostring(k) .. ": "
end
if type(v) == "table" then
log(prefix .. s .. "{")
printTable(v,prefix .. string.rep(" ",#s) .. " ", hash)
log(prefix .. string.rep(" ",#s) .. "}")
else
hash[v] = prefix;
if type(v) == "string" then
v = v:gsub("\t", "\\t")
v = v:gsub("\r", "\\r")
v = v:gsub("\n", "\\n")
end
log(prefix .. s .. "(" .. type(v) .. ") " .. tostring(v))
end
end
if top then
log(pref .. "}")
end
end
-- A debugging function to convert any LUA objet to a string
function tableToString(tab)
return tostring(tab)
end
local k,v,s
s = "{"
if s ~= "{" then
s = s .. ", "
end
s = s .. tableToString(k)
else
s = s .. tostring(k)
end
s = s .. "="
s = s .. tableToString(v)
else
s = s .. tostring(v)
end
end
s = s .. "}"
return s
end
-- Here is where we automatically discover the bridge's IP address.
function FindPlatinumBridgeIPAddress(prevIp)
local udp = socket.udp()
udp:setoption("broadcast",true)
udp:settimeout(1.0)
local broadcast_ip = '255.255.255.255'
local NBNS_port = 137 -- Netbios Name Service
-- Netbios Name service query "PLATLINK-FDBU<00>"
local NbnsQuery = "\000\001\001\016\000\001\000\000\000\000\000\000 FAEMEBFEEMEJEOELCNFAEEECFFCACAAA\000\000 \000\001"
udp:sendto(NbnsQuery, broadcast_ip, NBNS_port)
local response, bridgeIp, peerPort = udp:receivefrom()
udp:close()
if response then
if prevIp == bridgeIp then
log("NBNS query consistent response: bridgeIp=" .. tostring(bridgeIp))
StartProtocol(bridgeIp)
else
-- At boot, the bridge sometimes returns bogus IP addresses like 192.168.xx.90 where
-- xx increments every 500ms until it gets the real IP address from the DHCP server
-- So we wait until we get a consistent answer twice in a row in 1 second intervals.
log ("NBNS query first response: bridgeIp=" .. tostring(bridgeIp))
prevIp = peerIp
luup.call_delay("FindPlatinumBridgeIPAddress", 1, bridgeIp, true)
end
else
log("Cannot find Platinum Bridge: " .. bridgeIp)
luup.call_delay("FindPlatinumBridgeIPAddress", 1, "", true)
end
end
-- Once we have found the bridge's IP address, we open TCP port 522 to start the session.
-- This also sets up the keep-alive timer
function StartProtocol(bridgeIp)
local platinum_port = 522
luup.io.open(PlatinumShade_Device, bridgeIp, platinum_port)
log("Opening TCP socket at IP address: " .. bridgeIp .. ":" .. platinum_port)
PlatinumShade_ConnectTime = os.time()
PlatinumShade_Connected = 1
if not PlatinumShade_PollStarted then
PlatinumShade_PollStarted = true
luup.call_delay("PlatinumPoll", PlatinumShade_pollInterval, "", true)
end
end
-- This is the first function to be called when the LuaUPnP engine first starts (or restarts)
function PlatinumShade_Startup(lul_device)
log("Startup(lul_device="..lul_device..")")
PlatinumShade_Device = lul_device;
FindPlatinumBridgeIPAddress("")
InitializePlatinumDb()
return true,'ok','Platinum Shade'
end
-- Initialize the internal database with whatever Vera knows about the shades
-- We correllate this with the shade database that we receive from the bridge
-- before we do the sync to add new shades or delete old ones.
function InitializePlatinumDb()
for k, v in pairs(luup.devices) do
if v.device_num_parent == PlatinumShade_Device then
local id_str = v.id
local id_prefix = id_str:sub(1,1)
local id_num = tonumber(id_str:sub(2))
if id_prefix == "S" then
PlatinumShade_Db.shades[id_num+1] = {shade = id_num, device=k, description=v.description}
elseif id_prefix == "R" then
PlatinumShade_Db.rooms[id_num+1] = {room = id_num, device=k, description=v.description}
else
log(ANSI_RED.."Error: Unkown ID: ".. tostring(v.id)..ANSI_RESET)
end
end
end
log("InitializePlatinumDb complete.")
printTable(PlatinumShade_Db)
end
-- This sends a periodic keep-alive message to the bridge
-- to maintain the connection
function PlatinumPoll()
log("Polling")
if PlatinumShade_Connected >= 4 then
Enqueue("$dmy", "^%d %$ack")
end
end
function Dequeue()
-- log("Dequque: Queue depth="..#PlatinumShade_Queue.." WaitingFor="..tostring(PlatinumShade_WaitingFor).." ActLevel="..tostring(PlatinumShade_ActLevel).." Queue="..tableToString(PlatinumShade_Queue))
while #PlatinumShade_Queue > 0 and PlatinumShade_WaitingFor == nil and PlatinumShade_ActLevel == 0 do
local t = table.remove(PlatinumShade_Queue,1)
PlatinumShade_WaitingFor = t.wait
if not Outgoing(t.data) then
return false
end
end
return true
end
-- Enqueue data to send but don't send any more data until we get a specific response
-- wait can either be nil to not wait, a Lua pattern to wait for that specific pattern
-- to be received, or it can be numeric constant meaning that special processing is needed.
function Enqueue(data, wait)
log("Enqueue data="..tostring(data).." Wait="..tostring(wait).." queue depth="..#PlatinumShade_Queue.." WaitingFor="..tostring(PlatinumShade_WaitingFor).." ActLevel="..tostring(PlatinumShade_ActLevel))
table.insert(PlatinumShade_Queue, {data=data, wait=wait})
Dequeue()
end
-- Low level output function sends commands to the bridge
-- If an error occurs, assume that we lost the connection
function Outgoing(data)
log("Outgoing: " .. data)
local result = luup.io.write(data, PlatinumShade_Device)
if not result then
log("luup.io.write("..tostring(data)..", "..tostring(PlatinumShade_Device) .. ") returned " .. tostring(result))
return false
end
return true
end
-- This is a list of shade types indexed by shade type + 1
-- name - The shade type name
-- order - an array of feature numbers supported by this shade type in the order in which they should be used
-- xover (optional - if shade has more than 1 feature) - The crossover point as a percentage value. Below this value, the second feature is used.
-- tdbu (optional) - Indicates special handling for top-down/bottom-up shade types
-- feature - an object matching the feature numbers to names
-- The last index (all) includes features common to all shades.
platinum_shade_types = {
[ 0+1]={name="Alustra Woven Textures: Roller", order={4}, feature={[4]="Bottom-Up"}},
[ 1+1]={name="Duette & Applause Honeycomb Shades: Standard", order={4}, feature={[4]="Bottom-Up"}},
[ 2+1]={name="Duette & Applause Honeycomb Shades: DuoLite & Top-Down/Bottom-Up", order={4, 18}, xover=50, tdbu=true, feature={[4]="Bottom Rail", [18]="Middle Rail"}},
[ 3+1]={name="Duette & Applause Honeycomb Shades: Top-Down", order={4}, feature={[4]="Top-Down"}},
[ 4+1]={name="Duette & Applause Honeycomb Shades: Skylift", order={4}, feature={[4]="Bottom-Up"}},
[ 5+1]={name="Desgner Roller & Screen Shades", order={4}, feature={[4]="Bottom-Up"}},
[ 6+1]={name="Luminette Privacy Sheers", order={4, 19, 7}, xover=20, feature={[4]="Traverse", [19]="Close left", [7]="Close right"}},
[ 7+1]={name="Luminette Modern Draperies: Full Panel", order={4}, feature={[4]="Traverse"}},
[ 8+1]={name="Luminette Modern Draperies: Dual Panel", order={4, 19, 7}, xover=20, feature={[4]="Traverse", [19]="Close left", [7]="Close right"}},
[ 9+1]={name="Pirouette Window Shadings", order={4}, feature={[4]="Bottom-Up"}},
[10+1]={name="Silhouette & Nanticket Window Shadings", order={4, 7}, xover=20, feature={[4]="Bottom-Up", [ 7]="Vane"}},
[11+1]={name="Vignette Modern Roman Shades: Traditional", order={4}, feature={[4]="Bottom-Up"}},
[12+1]={name="Vignette Modern Roman Shades: Tiered", order={4}, feature={[4]="Bottom-Up"}},
[13+1]={name="Vignette Modern Roman Shades: Tiered Top-Down/Bottom-Up", order={4, 18}, xover=50, tdbu=true, feature={[4]="Bottom Rail", [18]="Middle Rail"}},
[14+1]={name="Skyline Gliding Window Panels", order={4}, feature={[4]="Traverse"}},
[15+1]={name="Pleated Shades", order={4}, feature={[4]="Bottom-Up"}},
[16+1]={name="Alustra Woven Textures: Roman", order={4}, feature={[4]="Bottom-Up"}},
[17+1]={name="Solera Soft Shades", order={4}, feature={[4]="Bottom-Up"}},
[18+1]={name="Design Studio Roman Shades", order={4}, feature={[4]="Bottom-Up"}},
all ={name="Features common to all shades", order={10,01,12}, feature={[10]="Intermediate stop", [01]="Sync", [12]="Test"}},
local weekdays = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday" }
-- This is called whenever a shade is changed either by vera or by the platinum app on the mobile device
function UpdateShade(shade_id, feature, position)
local shade = PlatinumShade_Db.shades[shade_id+1]
shade.deleted = nil
if feature == 1 then -- Sync
log("UpdateShade: ignoring sync to shade " .. shade_id .. ": " .. tostring(shade.description))
return
elseif feature == 12 then -- test
log("UpdateShade: ignoring test to shade " .. shade_id .. ": " .. tostring(shade.description))
return
elseif feature == 10 then -- Intermediate stop. We don't know exactly where that is so assume 50%
log("UpdateShade: Assuming intermediat stop at 50% for shade " .. shade_id .. ": " .. tostring(shade.description))
shade.feature = 4
shade.position = 128
else
shade.feature = feature
shade.position = position
end
if shade.device then
local room = PlatinumShade_Db.rooms[shade.room+1]
local shade_type = platinum_shade_types[room.type+1]
local percent
local status = 0
if shade_type.tdbu then
-- special case for top-down/bottom-up shades
if shade.feature == shade_type.order[1] then
percent = shade_type.xover + math.floor((shade.position * (100-shade_type.xover) / 255) + .5)
else
percent = shade_type.xover - math.floor((shade.position * shade_type.xover / 255) + .5)
end
if percent ~= shade_type.xover then
status = 1
end
else
if #shade_type.order > 1 then
else
percent = math.floor((shade.position * shade_type.xover / 255) + .5)
end
else
percent = math.floor((shade.position * 100 / 255) + .5)
end
if percent > 0 then
status = 1
end
end
luup.variable_set("urn:upnp-org:serviceId:Dimming1", "LoadLevelStatus", tostring(percent), shade.device, false)
luup.variable_set("urn:upnp-org:serviceId:WindowCovering1", "LoadLevelStatus", tostring(percent), shade.device, false)
luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Status", tostring(status), shade.device, false)
end
end
-- Loose string matching used for room names
-- Case and whitespace are ignored in the comparison. n2 can be a prefix of n1
function NameMatch(n1, n2)
return string.find(string.lower(string.gsub(n1,"%s","")), string.lower(string.gsub(n2,"%s","")), 1, true) == 1
end
function TableLength(T)
local count = 0
for x in pairs(T) do
count = count + 1
end
return count
end
function URLEnclode(s)
return string.gsub(s, "%A", function(c) return string.format("%%%02X", string.byte(c)) end)
end
-- This is where we synchronize the device database which we received from the bridge with Vera's.
-- Vera will add or delete child devices to match what the bridge gives us.
-- This is not to be confused with a manual shade "sync" operation used when adding new shades.
function SyncDevices()
local children = luup.chdev.start(PlatinumShade_Device)
for id, shade in pairs(PlatinumShade_Db.shades) do
if shade.deleted then
log( "SyncDevices: Not appending shade " .. id-1 .. ": " .. shade.description .. ".")
PlatinumShade_Db.rooms[shade.room+1].shades[id] = nil
PlatinumShade_Db.shades[id] = nil
else
log( "SyncDevices: Appending shade " .. id-1 .. ": " .. shade.description .. ".")
luup.chdev.append(PlatinumShade_Device, children, "S"..id-1, shade.description, "urn:schemas-micasaverde-com:device:WindowCovering:1", "D_WindowCovering1.xml", "", "", false)
end
end
for id, room in pairs(PlatinumShade_Db.rooms) do
if room.deleted then
log("SyncDevices: Not appending room " .. id-1 .. ": " .. room.description .. " shades.")
PlatinumShade_Db.rooms[id] = nil
elseif TableLength(room.shades) > 1 then
-- Create a device to change all shades in a room if the room has more than one shade
log("SyncDevices: Appending room " .. id-1 .. ": " .. room.description .. " shades.")
luup.chdev.append(PlatinumShade_Device, children, "R"..id-1, room.description .. " shades", "urn:schemas-micasaverde-com:device:WindowCovering:1", "D_WindowCovering1.xml", "", "", false)
end
end
for id, scene in pairs(PlatinumShade_Db.scenes) do
if scene.deleted then
log( "SyncDevices: Deleting scene " .. id-1 ..".")
PlatinumShade_Db.scenes[id] = nil
end
end
for id, schedule in pairs(PlatinumShade_Db.schedules) do
if schedule.deleted then
log( "SyncDevices: Deleting schedule " .. id-1 ..".")
PlatinumShade_Db.schedules[id] = nil
end
end
luup.chdev.sync(PlatinumShade_Device, children)
-- Now go through all child devices and set the rooms if there is a name match
local id_prefix = v.id:sub(1,1)
local id_num = tonumber(v.id:sub(2))
local room
local shade = PlatinumShade_Db.shades[id_num+1]
if not shade then
break
end
else
room = PlatinumShade_Db.rooms[id_num+1]
end
if not room then
break
end
for i = 1, #luup.rooms do
if NameMatch(room.description, luup.rooms[i]) then
log("Vera Device " .. k .. ": " .. URLEnclode(v.description) .. " - Bridge room " .. room.description .. " matches Vera room " .. luup.rooms[i])
if v.room_num ~= i then
log("Device=" .. k .. " old room_num=".. v.room_num .. " New room_num=" .. i);
-- For some reason, the call to luup.attr below to change the room does not always work, so we use a roundabout approach.
--luup.attr_set("room_num", tostring(i), k)
local response, status, headers, statusline = http.request("http://127.0.0.1:3480/data_request?id=device&action=rename&device="..tostring(k).."&name="..URLEnclode(v.description).."&room="..tostring(i))
-- log("response="..tostring(response).." status="..tostring(status).." headers="..tableToString(headers).." statusline="..tostring(statusline))
end
break
end
end
end
end
log("SyncDevices complete")
end
-- This is where we parse any incomming status messages from the bridge
function PlatinumShade_Incoming(data)
local handled = false
log("Incoming: " .. string.format("%q",data))
-- Remove any leading 0 bytes
while string.byte(data,1) == 0 do
data = string.sub(data,2)
end
-- $act01-00- Start action
-- $act02-<room>- Action in room
-- $act00-00- End action
-- $act messages may come due to our own actions or someone elses. We must wait until the
-- action is completed either way.
local act_level_str, act_arg_str = string.match(data, "^%d %$act(%d%d)-(%d%d)-.*$")
if act_level_str ~= nil then
PlatinumShade_ActLevel = tonumber(act_level_str)
handled = true
end
-- see if the data matches a response that we were waiting for previously
if type(PlatinumShade_WaitingFor) == "string" and string.match(data, PlatinumShade_WaitingFor) then
elseif string.match(data,"HunterDouglas Shade Controller") then
PlatinumShade_Connected = 2
-- Set the date as $sdt02-21-07-2015-
-- os.date returns Monday=1...Sunday=7
-- $sdt needs Sunday=1..Saturday=7
local dayOfWeek = tonumber(os.date("%u"))+1
if dayOfWeek > 7 then
dayOfWeek = 1
end
local dateString = os.date("$sdt%m-%d-0"..dayOfWeek.."-%Y-")
Enqueue(dateString,"^%d %$done")
local timeString = os.date("$stm%H-%M-%S-")
-- Set time as $stm06-52-54-
Enqueue(timeString,"^%d %$done")
-- Get the first status inquiry
Enqueue("$dat-", kUPD01)
PlatinumShade_Connected = 4
elseif string.match(data, "^%d %$done$") and PlatinumShade_WaitingFor == KShadeActionPending then
-- $done - returned in response to $sdt (set date) and $stm (set time) and $pss (set shade position) commands
-- Special handling for multiple pss commands in a scene.
if #PlatinumShade_Queue > 0 and PlatinumShade_Queue[1].wait == KShadeActionPending then
Outgoing(PlatinumShade_Queue[1].data)
else
PlatinumShade_WaitingFor = "^%d %$act00-00-"
Outgoing("$rls")
end
elseif string.match(data, "^%d %$reset$") then
-- $reset - A new database is about to be sent. Mark all objects as deleted for now and we will remove them when we sync
for k,v in pairs(PlatinumShade_Db.rooms) do
v.deleted = true
end
for k,v in pairs(PlatinumShade_Db.shades) do
v.deleted = true
end
for k,v in pairs(PlatinumShade_Db.scenes) do
v.deleted = true
end
for k,v in pairs(PlatinumShade_Db.schedules) do
v.deleted = true
end
else
-- $cr - Create Room
-- 2 $cr00-10-0x056F-Dining Room
local room_id_str, room_type_str, room_hash, room_desc = string.match(data, "^%d %$cr(%d%d)-(%d%d)-(0x%x%x%x%x)-(.*)$")
if room_id_str ~= nil then
local room_id = tonumber(room_id_str)
local room_type = tonumber(room_type_str)
if platinum_shade_types[room_type+1] == nil then
log("Room="..room_id..
" type="..room_type.."="..ANSI_RED.."ERROR: Unknown type"..ANSI_RESET..
" description="..room_desc);
else
local room = PlatinumShade_Db.rooms[room_id+1]
if room == nil then
room = {}
PlatinumShade_Db.rooms[room_id+1] = room
end
room.room = room_id
room.type = room_type
room.description = room_desc
room.deleted = nil
room.shades = {}
" type="..room_type.."="..platinum_shade_types[room_type+1].name..
end
else
-- $cs - Create Shade
-- 2 $cs01-01-06-Front Window
local shade_id_str, room_id_str, hash8, shade_desc = string.match(data, "^%d %$cs(%d%d)-(%d%d)-(%d%d)-(.*)$")
if shade_id_str ~= nil then
local shade_id = tonumber(shade_id_str)
if room == nil then
log("Shade="..shade_id..
" room="..room_id.."="..ANSI_RED.."ERROR: Unknown room"..ANSI_RESET.." description="..shade_desc);
else
" room="..room_id.."="..room.description..
if shade == nil then
shade = {}
PlatinumShade_Db.shades[shade_id+1] = shade
end
shade.shade = shade_id
shade.room = room_id
shade.description = shade_desc
shade.deleted = nil
room.shades[shade_id+1] = true
if PlatinumShade_Connected >= 5 then -- Do this only when receiving an unsoliscited $cs command
SyncDevices()
end
end
else
-- $cp - Report Shade position
-- 2 $cp06-04-174-
local shade_id_str,feature_str,position_str = string.match(data, "^%d %$cp(%d%d)-(%d%d)-(%d%d%d)-.*$")
local feature_num = tonumber(feature_str)
local position = tonumber(position_str)
if PlatinumShade_Db.shades[shade_id+1] == nil then
log("Shade="..shade_id.."="..ANSI_RED.."ERROR Unknown shade"..ANSI_RESET)
else
local room_id = PlatinumShade_Db.shades[shade_id+1].room
local room_type = PlatinumShade_Db.rooms[room_id+1].type
if platinum_shade_types[room_type+1].feature[feature_num] == nil then
if platinum_shade_types.all.feature[feature_num] == nil then
log("Shade="..shade_id.."="..PlatinumShade_Db.shades[shade_id+1].description..
" room="..PlatinumShade_Db.rooms[room_id+1].description..
" type="..platinum_shade_types[room_type+1].name..
" feature="..feature_num.."="..ANSI_RED.."ERROR: Unknown feature for this shade type"..ANSI_RESET)
else
" common feature="..feature_num.."="..platinum_shade_types.all.feature[feature_num]..
" position="..position)
UpdateShade(shade_id, feature_num, position)
end
else
" feature="..feature_num.."="..platinum_shade_types[room_type+1].feature[feature_num]..
end
end
else
-- $cm - Declare scene, name
-- 1 $cm00-First Scene
local scene_id_str, scene_desc = string.match(data, "^%d %$cm(%d%d)-(.*)$")
if scene_id_str ~= nil then
local scene_id = tonumber(scene_id_str)
log("scene="..scene_id.." description="..scene_desc)
local scene = PlatinumShade_Db.scenes[scene_id+1]
if scene == nil then
scene = {}
PlatinumShade_Db.scenes[scene_id+1] = scene
end
scene.scene = scene_id
scene.description = scene_desc
scene.deleted = nil
if scene.shades == nil then
scene.shades = {}
end
if scene.rooms == nil then
scene.rooms = {}
end
else
-- $cp - declare shade in scene
-- 1 $cq00-08-01-
local scene_id_str, shade_id_str, enable_str = string.match(data, "^%d %$cq(%d%d)-(%d%d)-(%d%d)-.*$")
local enable = tonumber(enable_str)
if PlatinumShade_Db.scenes[scene_id+1] == nil then
log("Scene="..scene_id.."="..ANSI_RED.."ERROR: Unknown Scene"..ANSI_RESET)
elseif PlatinumShade_Db.shades[shade_id+1] == nil then
log("Scene="..scene_id.."="..PlatinumShade_Db.scenes[scene_id+1].description..
" Shade="..shade_id.."="..ANSI_RED.."ERROR: Unknown shade"..ANSI_RESET)
else
Truncated…
