Hello. I just switched from veralite to smarthings hub v2.0 last night. So far everything works but i can’t seem to find any way of using my hunter douglas motorized shades. I used this app before on veralite and it wasn’t perfect but worked ok.
anybody know of a way to get this working with smartthings? I’m not using the new powerview system that just got released but previous one powerrise 2.1 platinum setup.
SmartThings does not support simple TCP socket communication (a.k.a. “Telnet”). Currently, the hub can only talk over HTTP. Telnet functionality has been requested multiple times, promised and never delivered. There’s a hack that allows sending data, but you cannot receive.
install the device handlers, the smartapp, via ide
you need to download the status file per readme and host that somewhere you can get a URL to it and set that in preferences.
@schwark - thanks for smartapp I too struggle with this.
I accomplished ST-Hunter integration via IFTTT but it is a completely unreliable integration because Hunter cloud integration does not work half of the time or has long delays (10-30 seconds)
What you are describing is a different version of the gateway - called Powerview. I have the older one called Platinum gateway as do a.number of other SmartThings users. That is why I published this. I have not looked at the Powerview API - however you cannot migrate from one the other. Hunter Douglas tells me you have to get whole new shades to use the new platform.
I’m digging up an old thread here, but wanted to see if there were any more resources or documentation regarding this project.
I have some Silhouette shades which are controlled through a “non-branded” remote. Cross referencing the FCC ID on the remote reveals that this should be the same protocol as Hunter Douglas Platinum (aka “PowerRise”?, not to be confused with the more recent “Power View”?). So I’m looking to take a chance on a “Hunter Douglas PowerRise RF Bridge” to see if I can integrate with SmartThings and ultimately control the shades from the SmartThings app.
I’ve just started googling and stumbled onto your github repo for “smartthings-hunterdouglasplatinum”. Is there any other documentation / code I can read through to see what you and others have done in the past so I can make sure I understand all the requirements before I move forward?
Took the plunge and got a Platinum Bridge. The units works with my shades. Verified through the regular Hunter Douglas Platinum.
Onwards to SmartThings integration:
Used IDE to install and publish all three device handlers
Used IDE to Install and publish SmartApp
Ran getstatus.py to download the (static) status and placed output.txt in an accessible location
Added “Platinum Gateway Bridge” device to SmartThings via IDE, making sure to add in hex-encoded IP (w/ port 522 at the end)
Added SmartApp to SmartThings via Mobile App, adding in URL for status and IP address (in decimal, no port at the end)
All this seemed to go well, but I’m not sure I understand what happens next. Are child devices (scene and shade switches) supposed to magically appear in my Devices menu? Or do I need to manually add those too? Still digging…
Also, looking into logs in the IDE, I saw the following exception being hit by the SmartApp when doDeviceSync() is called every 5 minutes:
I added a few debug statements to better understand how the SmartApp was parsing the status file (output of getstatus.py).
Turns out mine had a blank line at the top. This was causing the parsing code to choke when trying to find the 1st prefix:
info.eachLine() { line ->
line = line.trim()
if(!prefix) {
prefix = line[0..1] // This will choke if a blank line is first
log.debug("prefix is set to ${prefix}")
else if(!line.startsWith(prefix)) {
return
Now that I’ve removed the blank line from my file, updateStatus() completes successfully and adds a “Switch” device for each Scene that was previously set up through the Platinum App (this is probably the preferred method - rarely do we want to operate individual shades). Toggling the switch to “ON” will cause the Scene to run. Toggling the switch to “OFF” appears to have no effect.
@Derrek113116 - you mentioned you have a hub “similar” to powerrise. You may want to confirm that it is indeed the Platinum Bridge, and not the later versions of Hunter Douglas technology. For example, my Platinum Bridge shows the following info underneath:
Yep my bridge says the same exact thing, can anyone walk me through this I can get the device handlers and app, just don’t understand the hosting/python stuff
