Hub v2 missing information
Hi @Itati
Not welcome code related but hope you’re able to help with a v2 hub related issue.
I dug out a spare brand new hub v2 which I activated via the code in the box. I can see the hub as connected in the App but it’s not reporting the firmware version nor the DSK/SDK versions. How can I update the firmware please?
Also, I was disappointed not to be able to form a hub group with the existing v2 hub as you can’t with 2 x v2’s, so resigned myself that at least I can do a “backup” in case the existing hub fails. BUT, upon going into the hub replace options apparently there is not enough memory on an identical hub!?!
Please advise
Thanks in advance
Which Samsung/SmartThings hubs support Hub Groups and Hub Backup?
Aeotec Smart Home Hub, Samsung SmartThings Hub 2018 (Hub v3), SmartThings Station, Samsung Smart TVs*, Family Hub refrigerators*, Samsung Smart Monitors*, Samsung Soundbar
  • Hub Groups and Hub Backup currently only support models with Thread/Zigbee radios built-in. Models that require Zigbee/Thread radio dongles are not supported, even if a dongle is installed.
Hi, @Somebody
Itati is OOO at the moment, but as we’re from the same team, I can help you out.
So, let’s separate the issue into two parts:
  1. The V2 Hub is installed but it doesn’t report the firmware version. Did you get any erros while onboarding it? If not, please share the following information:
    • Serial number
  2. The hub you wanted to use as backup is the one you don’t see information from, right? The one that ends with “_Garage”. If so, it might showing this error because its information is complete, so, I think we should solve the issue #1 first.
For both issues, we need support access to your account, could you enable it, please?
  5. Select the time period and confirm - In this step, please select “Until turned off”, once the team finishes, we’ll let you know so you can disable it again
You have DM. Thanks
