How to update old SmartTings Hub V2 firmware?
Hello.
I had a very old SmartTings Hub v2.
I respect that you are still supporting the hub of the old version.
The firmware of the Hub V2 I currently own is 014.00032, which doesn’t seem to be automatically updated.
I found that the hub of 028.00012 firmware version in the community was supported and successful.
Hub V2 is not updating the firmware - Developer Programs / Support - SmartThings Community
Should I just activate the Toggle On Account Data Access feature and wait?
I’ll be waiting for the good news.
Have a nice day
tagging @Itati @nayelyz
Hi @nullnull3
To help force the update, could you please assist by following these steps?
For these hubs, blocking NTP traffic during hub claim can allow the hub to connect to the hub firmware update server. This does require administrator access to your router and the ability to set Access Control Rules. The following steps outline how users with the necessary permissions and equipment access can proceed:
  1. Locate the steps provided by your home network router manufacturer to access the Router Settings / Admin Interface.
  2. In your Router settings, navigate to Access Control Rules and create a rule to disable UDP port 123 (NTP). (What is NTP Wiki). Please be sure to set only the source port as 123 and do not specify a destination port.
  3. Factory reset the SmartThings/Aeotec Hub.
  4. Go through the standard onboarding/hub claim process outlined in the hub documentation provided with the device.
    If you still have trouble claiming, please collect hub logs as outlined in the Troubleshooting section below before rebooting.
  5. Once the hub has successfully onboarded, remove the Access Control Rule created to block UDP Port 123. At this time, the hub should have updated its firmware to the latest supported version.
** If blocking the NTP port is not functional, another option some users have had success with, is blocking URLs for your specific region within the Access Control or Parental Controls. Here is a guide to find your NTP server for your specific region.
