I have had some major issues from my motion sensor re installed the app on my iphone today ,now the hub is asking for code as a new installation ,when i tried using the orginal code says has been used already which i know .Is there a way round this so i can get all my set up fixed or do i need to call samsung on monday for a new code any help will be most grateful thanks in advance
I’m afraid you are going to the support to reset the code for you. I have never had to deal with this situation but I can’t imagine any other way.
- You can reset HUB
2.Deteach HUB out of account smartthings - Add the Hub, Device again.
Connected Things
Wonderful, thanks for that information. Seems there is a way out for you short of contacting support.
Hi thanks for suggesting that what i am getting is my code has already been used which it has so how can i get the orginal code to be accepted thanks
The only way in this situation is to contact Support@SmartThings.com. They need to reset the single use code.
Be sure to include a photograph of your Hub’s serial number, and a statement giving SmartThings full permission to access and reset your Account with the associated email address of your login.
Will do that thanks …
