@Danielhitch, do you have any more details about your setup or what symptoms you were seeing? I just installed that smartapp and everything seems to be working on the 2 bulbs I have at my desk using a hub on 20.10.
Some specific questions that would be good to answer: What version of hue bridge do you have? When did you first notice there was an issue?
It may be unrelated to the beta update but seems very coincidental. Iām running a v2 hue hub and a v2 smartthings hub. Hue hub is running firmware 1801260942.
Outage started this evening after a short outage which I am guessing was the new beta update
If you wanted to set things back up you could use the send logs utility in graph after you see the issue (and let me know) and I could take a look at what is going on in the hub when itās not working. However I assume itās probably not related to the beta. The update didnāt actually start going out until ~30 minutes after youād posted. That unfortunately also means that the logs form when you were having the issue are definitely gone now because your hub will have rebooted since to apply the update.
All of my xiaomi zigbee open close sensors have gone offline this morning after the beta push. This hasnāt happened before. All xiaomi temperature sensors, motion sensors still work and report correctly just not the dozen or so open close sensors. All are aqara models using bspranger a4refill fork. Any thoughts on how to troubleshoot?
I have two Aeotec by Aeon Zwave plus dry contact sensors (7W097). Both are periodically missing an update from open back to close status. Opening and reclosing the doors a few times seems to update the hub back to door close status. May be unrelated but I have not seen this occur before the Beta 21.X.
Description: Every time I switch one of these bulbs on or off, I get duplicate events. For instance, if I turn the light on, I would expect ONLY one event in the IDE Events Log, instead Iām seeing two. These are supported bulbs by Samsung and Iām hoping now that Iām a BETA user, you can work with me to fix this issue. Itās causing issues with some of my programs because of the duplicate event logging. Thank you.
I have one of these and just tested it today repeatedly and seems to be working fine for me, what DH are you using? I am using the āZ-Wave Plus Door/Window Sensorāā¦
I see, I decided to put up with the sensor reporting status backwards so I could have local execution. I was thinking on creating a Custom DH just to be able to change the sensor setting from Always Closed to Always Open, then we could switch back to the standard DH and enjoy proper status report AND local execution⦠Iāll see if I can spend some time on that this weekendā¦
Anyway, it may be a problem with that Custom DH, but you said it was working fine so may be better to just create a bug report in center code and let them check it for you.
