I have a ton (98) of Z-Wave GE devices. All dimmer, on/off, outlet devices.
All my devices are represented on a SmartTools dashboard (I keep an eye on them constantly)
Recently, (in this very thread), I had a GE Z-Wave Paddle on/off switch for my garage light go “offline”
When I dove into the Smarthing Devices, I noticed this “Z-Wave” device (unlike 27 of my other devices) was no longer marked with a “device network ID” and had a “driver” of “placeholder”. Again, none of my other Z-Wave switches had this driver, only this one.
Unfortunately, I lost access to the switch, so I took the steps of removing and re-adding this switch to the HUB and - as expected these days - it came over with an Edge Driver. I regained access to the switch, added it to my routines, and all was well - except…
GE Switches have an “indicater” LED light. It has always been a bit finicky, but you can manipulate the LED light to do one of three things:
Always off
On when on
On when off
Because most of my light switches are in banks of three or four switches, I prefer “On when On” so you know which switches are actually “on”…
-------------------------------------------------------------(TL/DR)---------------------------------------------------------------
When this GE Z-Wave Paddle Switch moved from Groovy to Edge, I lost the ability to control the “indicator LED”. It is typically an option under “Settings” / “LED Indicator”. The new “Edge” driver does not provide this option. “Settings” in not even a menu option for Edge.
The switch: Enbrighten, GE Model # 46201
The current DTH: “Z Wave Switch” (Generic) - 2022-08-02T20:09:30:783624788
The driver before the switch?
“Z-Wave Switch” - not custom…
Details from Graph API (similar switch)
zw:L type:1001 mfr:0063 prod:4952 model:3036 ver:5.22 zwv:4.54 lib:03 cc:5E,56,86,72,5A,85,59,73,25,27,70,2C,2B,7A role:05 ff:8700 ui:8700
