I linked to the wrong thread the first time. My bad. It should be:
Hub Firmware Beta Group, get ready to migrate!
I have corrected my post above.
@csstup is right, @Mariano_Colmenarejo. The team has seen the same behavior with other migrated devices, the values in âRouteâ and âmetricsâ remain the same before the migration. This means this value wonât be up-to-date.
Canât wait to see these current values for Edge based Zwave/Zigbee devices in the CLI!
Thereâs now an official virtual switch Edge driver in production
Is there something we need to sign up for to acces that, like we did/do for the Edge beta channel?
My speculative guess is that it will be tied in with the virtual devices the CLI can create and this will be the local version.
yeah, it remains to be seen how to actually create a virtual device that uses that driver. At the minimum, I assume it will used to migrate existing devices that use the default virtual switch and simulated switch DTH. Thereâs already a couple community created virtual device drivers that are more flexible and easy to use, so I donât know if iâd ever use this default option.
I donât suppose itâll be that different to how it was for the DTH version. Just an API call from wherever. When I was reading the code last week I noticed it has the state change flag set like the DTH does so it fits the bill for a straight swap. I didnât think to test how the virtual switch created via the CLI behaves in that regard. I have lots of virtual devices created with community Edge drivers and I am hoping to be able to replace all of them with a stock solution.
You can swap stock driver now, but you want be happy with it. I doesnât have all extras that community created have
Iâm holding off for the moment as they clearly arenât ready (and, to be fair, they arenât claimed to be). Some, like the virtual switch, will work but others are pretty much useless as they donât have commands. Using the API to set attributes is not a practical option. Iâll also need to have local and cloud options. Very few âextrasâ are of interest to me.
A post was merged into an existing topic: Hub Firmware Beta Group, get ready to migrate!
Smartthings Home Connect and Smartthings Wifi are already Edge ready. Latest update this month.
Anyone having issues with connect hub updated to latest firmware and still dont see edge drivers ?
Hub model # ET-WV520
Could be related to Thursdays ST cloud issues, which have reportedly been fixed.
Have you attempted to subscribe to any of the Beta Edge Channels from any of the Developers to see if that changes? Would be interested to see if it changes
@jkp When I enroll in beta program, drivers show up as expected .
I have two connect hubs at two different locations and both behave the same way.
Thanks @Paul_Oliver . That explains many failed attemps yesterday adding Ikea button. That page says the issue has been resolved now but, my hubs still dont show edge driver option .
Where is it not appearing? The picture you shared above belongs to the âDriverâ option inside the Hub
It says you have enrolled to that channel but, have you installed any driver? For example:
You need to check if your device is supported in that driver, you can check their fingerprints in the official driversâ repo:
I ran into a similar issue myself when a Z-Wave switch, overnight, switched to Edge.
The only thing you can do is to shut off the âindicatorâ LED and hope the Edge Drivers support this later on.
You can manually toggle the LED setting using the âup-up-up / downâ technique.
Quickly hit UP three times, then Down once.
I found I could only activate two modes:
On when off
Always off
I actually prefer âon when onâ - so mine are âoffâ for now
Can you provide more details, please?
