Does anyone know how to access the old system where we could load handlers and see what is happening with our devices behind the scenes now that accounts.smarthings takes us to a new dashboard? Cheers
jkp
August 3, 2022, 9:19pm
2
http://ide.smartthings.com or https://graph.api.smartthings.com
Go to My Locations and tap on the Location name and then proceed as normal.
just a reminder: it is part of the legacy platform and it will be going away once ST completes the migration to Edge and LUA.
Thanks, so how are we going to be able to change handlers on devices etc?
jkp
August 3, 2022, 9:23pm
4
Device Handlers will be phased out and Edge Drivers will replace them. Those can be changed in the ST app. You should look at CLI. It is in the following thread.
As of September 2023, SmartThings has now almost completed transition to a new architecture, part of which is called Edge.
The Samsung-hosted free groovy cloud gradually went away beginning on September 30, 2022. For hub-connected devices, including Zwave and Zigbee, the DTH replacement will be Edge Drivers, which are written in the Lua programming language and will run locally on your own hub.
IF YOU ARE NEW TO SMARTTHINGS
If you are new to SmartThings, the basics of the SmartThings architecture are pretty simple:
A) An “Edge Driver” is code that runs on your SmartThings/Aeotec hub so the hub can talk directly to an individual device. If you don’t have a hub, you can skip all the rest of this thread: it won’t apply to your setup.
B) If your device uses a “cloud to clo…
Sorry but I cant seem to find my location
jkp
August 3, 2022, 9:25pm
7
click on one of the links I posted above.
yeah sorry just figured that out lol, thanks again
