Please, when this kind of thing happens, try not to modify the device so the team can get the corresponding logs to check what could’ve happened.
In your case @Cory_Booth, all the corresponding logs cannot be found because you reinstalled the device.
However, the team mentioned that there was no automatic migration done, so it’s not clear what happened in your case.
When will migration to Edge drivers happen; is it already in progress? If I am running a custom DTH on a device, will it migrate to the Edge driver for that device?
I was just about to confidently answer that question when I realised I may not know the answer. A small but increasing number of devices that were fingerprinted for stock device handlers are now fingerprinted for Edge drivers and so will switch over when re-paired for any reason, and the hub beta firmware testers have been borrowed to help test the automation migration progress from stock DTH to stock Edge. I don’t know what happens with devices using stock handlers without fingerprints. There will be certainly be generic fingerprints but I don’t know how effective they will be, especially for those who had to select the device handlers manually. I’ve forgotten, or never knew, what the process will be for getting users off of custom handlers.
I thought it might be that, but it seemed a bit inconsistent with past transitions where there has been a reluctance to let users stew in their own juices.
There hasn’t been an announcement about the public migration, so it’s unlikely.
However, those that are part of the Hub’s firmware beta group might receive the auto migration for certain devices (take a look at this announcement). This file includes the devices involved in this process.
Is that device supported by a stock DTH or you’re using a custom one because it wasn’t accepted before?
Thanks for replying. It’s a custom DTH for an Aeotec multi-sensor 6, which does have a stock DTH. Would you suggest I revert to that for a smoother transition when the time comes for migration?
I would wait for the official announcement about the migration to know how it will work, but let me verify with the engineering team.
Update:
The team mentioned that the official announcement about the migration will include information about this kind of case. Once it comes out, we’ll know if there’s something we need to do to prepare our devices for the auto migration.
Hi,
i have several GE Z-Wave Paddle Switch and it are some as ZWAVE switch and some as switch-binary. last ones (placeholder) have different menus on the app. last ones can not be fix led light indicator. is there a way to change it. they are factory ligth off led on, i want to have ligth off led off.
best regards
Now that I logged into my IDE account I have seen that my Aeotec gen5 siren has automatically migrated to the stock Z-Wave Siren edge driver without any problem.
I don’t know when it happened.
I just left it with the stock DTH to see how it would migrate to an edge driver.
What I have seen differently is that in IDE and App it is shown as a device installed in the hub and with the metrics, route and information similar to DTHs, except for the states.
It seems that only the edge drivers in production have that information in the IDE.
I’m going to guess those are stale values from the device when it was under the DTH. Notice the last update/reset time on the metrics is from the 6th. And the last overall update time is the 7th. The conversion to Edge isn’t clearing or setting those values.
Anyone have an issue where a device will not convert to Edge?
I have a Inovelli Dimmer that is covered by the Z-Wave Switch Edge driver, when I change the DH to Z-Wave Switch Secure in the IDE, for some reason this device does not get converted to an Edge driver.
The Inovelli Dimmer is in the fingerprints for the Z-Watch Switch Edge driver.
If I understand what you’re asking, you can’t use the IDE to manage Edge Drivers. The IDE is part of the old architecture.
Also, at least until recently, if you had a custom DTH on your account with the same fingerprint the system will choose that in preference to a stock Edge Driver.
So to switch you have to
Remove the device from your account.
Remove the custom DTH from your account.
Re-add the device, and this time it should pick up the edge driver.
These steps are required because Edge is still in beta. They have said that they hope eventually to make the cutover automatic, but we aren’t there yet.
What I was able to do in the past is have a device converted to Edge by switching the driver in the IDE to the generic Z-Wave Switch driver, this worked even if the driver was at one point a custom DTH.
Specifically, I did this with GE Jasco switches that were using a custom DTH, I converted them to the stock Z-Wave Switch driver and almost automatically they were converted over the Edge driver. Now I just need the default Z-Wave Switch driver to add Jasco parameters…coming soon per the Github pull request.
