Yes, that’s the link included on the FAQ page, however, to see if a device is supported, you need to take a look at the fingeprints.yml file and see if yours is included. For example, here are the ones for the driver zigbee-button:
There, only the fingerprint of SmartSense/button is uncommented, so, it will be the only one considered.
I did know to look at the.yml file. AND when I looked, I saw the ikea 5 button listed, but did not realize only the devices without the # sign next to them to active. (Aka Samsung Button).
I believe the V2 has MORE memory than the V3, doesn’t it?
But the question is “large load.” Lua is really lightweight, if you’re kept to a limit of 200 devices and 200 routines, it might be ok. Or maybe it will all blow up when you get over 40 devices or so, who knows? We’ll just have to wait and see.
Not only does the V2 hub have more memory, its processor is also faster than that of the V3. The only plus the V3 has over the V2 is wifi connectivity.
If it doesn’t say “placeholder“ it’s a traditional groovy DTH.
If it says “placeholder“ it’s part of the new architecture. It could be an edge Driver, it could be some kind of cloud to cloud integration, but it’s not a Groovy DTH.
Today I had a random GE Z-Wave Paddle Switch convert to “placeholder”
Of 95 devices, it was the only one…
It was originally named “Garage Light” of type “Z-Wave Switch”
It switched to “GE Switch” of type “binary switch” - “placeholder”
I had to remove and readd though because it did not actually control the light, in fact it didn’t do anything at all. When I readded, it came over again as “placeholder” but now the light works.
I run a dashboard and noticed the tile was blank today, so the change happened in the past 24 hours.
I am curious…
Was this part of a migration?
Will we be told when this switch happens?
And given that my switch didn’t work after the change, I think it would be imperative to know when devices might be changing so we can take action to fix critical devices.
I also noticed, that despite this Z-Wave device now (I assume) running Edge, it is still “cloud” hosted.
Devices using Edge drivers will list Cloud in IDE but they are local. IDE is part of the old groovy based architecture. It is going to be phased out at some point. Devices using Edge drivers or cloud-to-cloud integrations that are based on the new architecture don’t properly display all the info. Basically you will only get the Name, type = Placeholder and Execution = Cloud. Some cloud-to-cloud integration may show an extremely long NetworkID. Don’t freak when you start seeing Unknown Route now… it is expected for devices using Edge.
The IDE is part of the old groovy architecture and it doesn’t get full information on anything that’s marked “placeholder.“ So it will always say they run in the cloud even though they are running local. And there may be other issues as well with the IDE information, but they don’t affect the operation of the device.
I’m checking with the team what might have happened. Can you help me by sending over DM the email account where you have installed that device, please?
