Hub 2.0 and Everspring SM103
Anyone had success getting the Everspring SM103 to accurately display open/closed status? I can get it to pair fine and it shows up in the IDE as ZWave Open/Closed, but it continues to show as open when in fact I know it isn’t! Tried changing the device type in the IDE, but there isn’t actually an everspring device type.
I have 2 on hub 2.0 that migrated from v1 and they both work fine with the default zwave open/closed device type.
Thanks. I’ll try excluding and adding again. At least I know it should work!
Found the issue. Had to move the sensor closer to my hub and then it paired properly.
