I have been using smartrules for a while now…Used it on an Iphone 5S and just loaded it onto an Iphone 6S - was working fine but now I get the error listed above. It recognizes that I am logged in but it can’t load the devices - this is only on the 6S…well I didn’t want to log out of the 5S because I am afraid it might happen with it as well. Everything else is working fine. I have deleted smart rules, rebooted everything…no change. Any ideas?
That sounds like one of the occasional SmartThings OAuth issues that pop up randomly and soon go away. I know that they have been messing with OAuth recently in hope of getting the UK folks working, so that could be related. Are you in the US or somewhere else? I just logged out and back in on a few test devices and everything seems ok. How long have you been seeing this issue @David_Forsthoffer? Could you try it again and post a screenshot of the error.
tgauchat
4
FYI: I am experiencing the same problem with SmartTiles.
If someone (who does or doesn’t have SmartTiles), in the USA, would like to try, please use this link:
(redacted pending updates from SmartThings, since issue is confirmed.)
It just started this evening and has been this way for several hours. I tried to upload this file earlier but the website was set to read only? well finally able to upload this…here it is. The problem still exists.
We can’t OAuth Smart Apps. It’s broken in the U.S. This is a HUGE problem that needs immediate attention. If you try to OAuth to a Smart App not currently authed…it fails with the same “failed to load devices” error.
Just chiming in that I’ve had several user reports of similar issues with being able to authorize devices with SharpTools (and I’m getting destroyed in reviews – thanks SmartThings!).
From the limited posts I’ve seen in this thread, it looks like the authors of the SmartApps are able to continue to authorize, but other users cannot. Is it possible that SmartThings broke the OAuth workflow for self-published SmartApps?
Edit: I just tried with IFTTT (officially published) and it seems to be working fine, but SmartTiles doesn’t work for me and SharpTools doesn’t work if I use a secondary account.
tgauchat
18
To reiterate, @slagle is officially working on resolution, and has code from SmartTiles installer and a few other questions answered by myself and @625alex.
@slagle will be following up with the engineers who pushed yesterdays OAuth UK fix this morning.
I wish we were important enough to warrant an immediate rollback… Our combined installs must rival IFTTT… Well, most certainly US vs UK!
But if they rollback, it may be harder to trace the problem.
I updated SmartTiles website to indicate installer temporarily unavailable.
We have opened a Tech Support ticket, perhaps each of us should… “for the record”.
tgauchat
19
This “only” affects unofficially published SmartApps to Accounts other than the one that has the SmartApp definition. The same problem occurs in a UK test, BTW.
SmartThings marketplace published web services SmartApps like IFTTT, Amazon Echo, InitialState are unaffected (and actually seem to work in UK now… so that’s obviously the root cause… Blame the British!).
Please correct me if my synopsis is inaccurate.
tgauchat
20
It would be helpful for everyone affected to do the same (as we have been requested to do many times by SmartThings Community relations…). Thanks.
As of yesterday evening, web based standard OAuth to web services SmartApps fails with “Failed to load devices” (for SmartApps shared to other SmartThings users, but not published in the SmartThings native marketplace).
Our particular SmartApp: SmartTiles (installation link redacted)
Affects ~10 Developers (at least!) and potentially hundreds of Customers.
