How to pair Leviton Duplex Receptacle / 15A outlet
Hi,
I just purchased couple leviton duplex receptacle and trying to pair it with the hub. I selected Switches & Dimmer and then Leviton 15A Outlet / Duplex Receptacle, Connect Now, but it just says “Im looking for a switch” and doesn’t seem like it’s finding it.
Am I doing it wrong? any suggestion?
thanks,
Once the app is searching just press the button on the outlet.
If it doesn’t work fro there you should try sending the Z-Wave Exclude which performs a type of reset on the switch.
Steps here:
From there try pairing it again.
got it to work , thanks
