Would you mind sharing it?
also, regardless of the device handler, it doesn’t seem to fully connect.
I’m able to re-pair it but the logs don’t show any activity and the button doesn’t light up when I press the button.
Even with the default handler, shouldn’t the logs show activity?
edit:
I turned on debug logging in the settings and it does seem to be sending. I thought I read that the blue light should turn on with a button press.
[9dc8eca4-ab55-42cb-aab2-8239f7942ea1](https://graph.api.smartthings.com/ide/logs#9dc8eca4-ab55-42cb-aab2-8239f7942ea1) 9:03:09 AM: debug Thing: Parsing 'read attr - raw: DB8E0100120A5500210100, dni: DB8E, endpoint: 01, cluster: 0012, size: 10, attrId: 0055, result: success, encoding: 21, value: 0001'
[9dc8eca4-ab55-42cb-aab2-8239f7942ea1](https://graph.api.smartthings.com/ide/logs#9dc8eca4-ab55-42cb-aab2-8239f7942ea1) 9:03:05 AM: debug Thing: Parsing 'read attr - raw: DB8E0100120A5500210100, dni: DB8E, endpoint: 01, cluster: 0012, size: 10, attrId: 0055, result: success, encoding: 21, value: 0001'
[9df9sca4-abe5-41cb-aab3-834sf7942ea1](https://graph.api.smartthings.com/ide/logs#9dc8eca4-ab55-42cb-aab2-8239f7942ea1) 9:03:02 AM: debug Thing: Parsing 'read attr - raw: DB8E0100120A5500210100, dni: DB8E, endpoint: 01, cluster: 0012, size: 10, attrId: 0055, result: success, encoding: 21, value: 0001'
[9df9sca4-abe5-41cb-aab3-834sf7942ea1](https://graph.api.smartthings.com/ide/logs#9dc8eca4-ab55-42cb-aab2-8239f7942ea1) 9:02:57 AM: debug Thing: Parsing 'read attr - raw: DB8E0100120A5500210100, dni: DB8E, endpoint: 01, cluster: 0012, size: 10, attrId: 0055, result: success, encoding: 21, value: 0001'
[9df9sca4-abe5-41cb-aab3-834sf7942ea1](https://graph.api.smartthings.com/ide/logs#9dc8eca4-ab55-42cb-aab2-8239f7942ea1) 9:02:54 AM: info Thing: Set health checkInterval when preferences updated
[9df9sca4-abe5-41cb-aab3-834sf7942ea1](https://graph.api.smartthings.com/ide/logs#9dc8eca4-ab55-42cb-aab2-8239f7942ea1) 9:02:54 AM: debug Thing: Debug message logging enabled
[9df9sca4-abe5-41cb-aab3-834sf7942ea1](https://graph.api.smartthings.com/ide/logs#9dc8eca4-ab55-42cb-aab2-8239f7942ea1) 9:02:54 AM: info Thing: Info message logging enabled
[9df9sca4-abe5-41cb-aab3-834sf7942ea1](https://graph.api.smartthings.com/ide/logs#9dc8eca4-ab55-42cb-aab2-8239f7942ea1) 9:02:54 AM: info Thing: Updating preference settings
