I want to use the Sonoff Leak sensor SNZB-05P as a dry contact input sensor (by soldering wires to its contacts). Everything’s good except for the default Leak notification by Smartthings that I have to way to turn off.
Is there a way to turn it off?
Or a way to change the device type of the sensor from “Leak sensor” to “contact sensor”?
It used to be possible by going into the Notification settings in the app and turning off notifications for the device. The same was true for any default notifications that seemed to come from nowhere.
Leak detection is confusing. There are two places to control notifications outside of routines- One is the regular notifications and the other is the Home monitoring app. A bit of trial and error for me to get it working as I liked.
I have the same (problem?). Using Sharptools rules as my alarm system for all my water leak sensors. Sharptools High Priority alarm I even have to cancel/acknowledge manually before the alarm stops. Imagine that my water leak sensor goes off when sleeping!
Now and then I test a sensor with a wet finger (Also to show off) and indeed the standard Smartthings alarms also rings..
This having said… So what? If you have a water leak…
Living in two appartments in old communist blocs, I even bought some extra Ikea KLIPPBOK as they are nearly free. Water sensors are always too late. so…
So the issue I was having is that I was getting two notifications for each related leak activity. So you need to make adjustments in up to 4 places. 1) if you trigger notifications your own routine(s), then you may no longer need that. I removed mine as they were no longer needed. 2) For notifications in general, you can filter those off (On IOS go to Menu/Notifications/Filter select on/off- I’m currently using this notification. 3) The most confusing one is in the Life app. On IOS go to Life/Home Monitor/tap the gear/go to leaks and tap/Set Response and select your desired response when there is a leak. You can set multiple things. I’m currently using only a bell. Once you set the response, you’ll need to turn it on (it may do that automatically). 4) My leak detector has a buzzer that I turned off through the device configuration. Hope that helps.
That’s very helpful. I was able to turn off the default Smartthings notification for a specific water sensor that I want. Then create my own routine to trigger other stuffs using the wires I soldered to the sensor.
