How do I see the network configuration of my Aeotec Smart Home Hub? I installed it but in the app there seems to be no way to see any network information about it. I can see the firmware revision and that is it. How do I see what network it is on? How do I update the firmware? It seems like the smart things app will not let me do anything with this hub itself.
For now you can see the details under “My Hubs” in the Groovy IDE. Note the IDE is being phased out while Edge is phasing in.
https://graph.api.smartthings.com/
The firmware will update automatically. You can reboot and it will check firmware update at startup.
Thank you for the link. Is there a way to remote reboot? Or is power cycling the only way?
You can currently do a remote reboot using using the IDE, but that will go away with Groovy.
I do my reboots using a Meross WiFi plug. If you have a v2 hub you would need to remove the batteries.
