R_Foreman
(Effour)
November 19, 2015, 7:12pm
1
SmartThings support hasn’t been very helpful lately, not reply for weeks to my tickets.
I’m an original Kickstarter backer, and SmartThings worked great for a good year. But after many updates to the app it’s just started breaking, alot of buggy functionality and i’ve had to completely reset up the app and system more than once.
Anyways, I want to disable my Alarm at 6am. Simple routine setup. I deleted and setup multiple times, still not working.
Here’s my setup. Am I doing anything wrong?
Toasty
(Colin)
November 19, 2015, 7:14pm
2
open up the IDE and check the logs?
R_Foreman
(Effour)
November 19, 2015, 7:36pm
3
What’s that and how do I view?
slagle
(Tim Slagle)
November 19, 2015, 7:39pm
4
Can you try something for me? I’ve been looking for a new test case to see if my theory is correct.
Can you add a light to the routine and tell me if the alarm will then disarm/arm as you would expect?
R_Foreman
(Effour)
November 19, 2015, 8:44pm
5
I added a light to turn off and a second attempt for a light to turn on. Neither solved the problem and the alarm will not disable.
Any other ideas?
RichardH
(Richard)
November 19, 2015, 9:06pm
6
Make sure no dimming setting is running. Just heard that’s a bug they’re working on.
R_Foreman
(Effour)
November 19, 2015, 9:33pm
7
I removed all sonos connections and it it cleared the issue.
thanks.
slagle
(Tim Slagle)
November 19, 2015, 9:35pm
8
So to make sure I understand, when you added another device to the routine it worked?
R_Foreman
(Effour)
November 19, 2015, 9:43pm
9
No, I removed all Sonos smart apps.
I had a bunch in the setup, like turn on when alarm triggers, etc.
Removing them all and testing the disarm again resolved the issue.
My setup is simply.
2 X Door Sensors
1 X Leak Detector
1 X Siren
I was playing around with Sonos and never really got it working properly which was the cause of this issue.
slagle
(Tim Slagle)
November 19, 2015, 9:50pm
10
Interesting, thanks for the info!
