Druce
(Druce MacFarlane)
October 10, 2016, 5:52pm
1
I have seen reports that this works with the 2nd Genration SmartThings hub, but I am having issues with my 1st generation hub.
I am able to discover it, and add it, but after that I get no activity out of the logs.
For those unfamiliar, this was supposed to be a kwikset 910 without the buttons.
Druce
(Druce MacFarlane)
October 10, 2016, 6:58pm
2
Another interesting datapoint. While I get no events at all from the event list, when I issue a lock/unlock command to it, it lights up. So, SmartThings is talking to it, but it is not responding in a way that SmartThings expects.
diehllane
(Brian Diehl)
October 10, 2016, 7:14pm
3
Did you do the discovery close to the hub and then move the lock to the door?
Do you have a repeater that supports beaming close to the lock?
http://thingsthataresmart.wiki/index.php?title=Beaming
I know when I installed my 914, the instructions had me pair it while disassembled so I could put the lock close to the hub, and then install it.
Druce
(Druce MacFarlane)
October 10, 2016, 7:39pm
4
Yes, sadly. I tried this today, but to no avail. As the devices pair quickly, and the lock lights up when I issue a command, I don’t think signal propagation is the problem.
diehllane
(Brian Diehl)
October 10, 2016, 7:42pm
5
Can you check in the IDE under Devices to see what it’s set up as? It’s possible it isn’t set up as the correct Device Type.
Druce
(Druce MacFarlane)
October 10, 2016, 9:26pm
6
It’s setup as a generic Z Wave lock.
Druce
(Druce MacFarlane)
October 21, 2016, 9:51pm
7
Turned out to be a defective unit. This device works fine with SmartThngs
