Harmony Hub instability in firmware 4.10.30
I absence of full disclosure, over time, the brain forms a habit and belief that performing the certain action can actually cause the desired effect…
I am stuck having the same issue. Everyhing was working perfectly before the update and now its all hit or miss!! so frustrating!!! hope someone can figure this out.
I noticed the exact same thing. The issue is only for dimmers. THe switches can work. I’m thinking of making a workaround with IFTT for a switch that activates a home phrase to let me dim a group of lights
They must have fixed it because it’s working for me now.
Works for me too.
@Mbhforum @bago what did you do? Mine is still broken.
Nothing. I left it alone.
EDIT: One thing I’ve learned is that when things stop working, don’t jump right away. It may fix itself (or trying to fix it may make it worse).
I think mine is working now but i did a total reset and deleted my activities, added new ones, did a couple syncs and now it seems to work again. odd
I had issues again today, so apparently, it’s sporadic.
No dice here I have added and removed them several times and I cannot get it to work with the dimmers. ST issue or Harmony?
Works again now. build 26. july 2016 on my remote firmware 4.10.30
Yep mine is working too, a little slow but still working.
