“placeholder” means those devices have been migrated, or that there’s cloud-to-cloud integration already there. You should be fine, but to be sure, what wifi devices do you have?
That is the way it’s suppose to work, but since you have some custom handlers, you will need to get those Zooz drivers so that you can retain the same functionality that you had with the older device handlers, unless you want just the basic features. Here’s where you can find those drivers and get help with them:
In general, wifi devices communicate with ST thru a cloud integration (meross, tplink, etc). There are exceptions where an Edge driver is used for local control of a Wifi device but you’d know if you had set that up already.
Cloud integrations are not effected by the DTH->Edge transition.
Thanks so much for the link to the Zooz Channel. I have downloaded the needed Edge drivers but they only appear in my ST hub when I click on the three-dots. They are not showing on the specific device. Is this correct or do I need to delete and re-install all my Zooz devices for them to show at the device level?
You have to delete the device from the App; remove any specific DTH from the SmartThings IDE and then re-add the device within the App. You’ll know if this all worked because you’ll the “Driver” option listed when click on the device’s edit settings page! To clarify:
In the App click on the particular device, click on the three dots at the top right of the App screen, this will show a pop-up menu that should contain a list: Cancel, Information, Driver, Settings and Edit. If you see Driver then you’re good to go! (this is on an iPhone), On Android I see Edit, Settings, Driver and Information.
Thanks so much for this information. However, if I deleted all my Zooz custom DH’s (required for them to work with ST), delete the devices from the app and re-add them (with the new Edge drivers) will they still work? In other words, are the Edge drivers now functional and already completed with the ST migration?
I found it was easiest to do them one at a time. You can just comment out the fingerprint in your custom DTH (prefix “//” to the fingerprint lines associated with your device, save and publish). The handler will still be used for existing devices, but new devices won’t see it as available anymore. So you can migrate each device one at a time.
Also, if you have WebCoRE integration then that device will no longer show up in WebCoRE. As a consequence of these changes WebCoRE will also be deprecated.
Thanks for the suggestion. However I have no idea how to do this. Can’t I just delete the entire custom DTH and then delete/reinstall my specific Zooz device?
For example here is the first part of the custom DTH for one of the devices. Where would the // be added to the fingerprint lines?
Zooz Remote Switch ZEN34 v1.1.1
Changelog:
1.1.1 (02/07/2021)
- Added patch workaround to presentation for supportedButtonValues support in Automations.
1.1 (01/10/2021)
- Added new fingerprint
- Changed the way associations are implemented so that it assumes the associations were successfully saved when the device isn't joined with S2 security.
1.0.3 (11/14/2020)
- Fixed wake up interval
1.0.2 (11/11/2020)
- Fixed setting labels
1.0.1 (11/07/2020)
- Fixed issue with SmartThings converting string attributes into dates if they start or end with specific numbers like 34.
1.0 (11/06/2020)
- Initial Release
Copyright 2021 Zooz
Licensed under the Apache License, Version 2.0 (the “License”);
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an “AS IS” BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
You can, but if you delete the custom DTH your existing devices that use it no longer work. I was trying to make it easier for you to migrate one at a time. If you only have 1 device OR you don’t mind doing them all at once, go for it.
Exclude all devices using the custom driver
Delete the custom DTH in the IDE
Make sure the new edge driver is installed
Include each device, after the first one make sure its using the driver you want it to (in the Driver tab under the hamburger/3 dot menu on the device).
I appreciate your suggestion and would prefer to edit the custom DTH but I don’t understand how to comment out the fingerprint? If I could do this I would do one at a time (5 devices using 3 custom DH).
Inside the editor, scroll down to the “fingerprint” section. Add two forward slashes (the comment seqence in Groovy) to the front of the line (or lines, depending on how many devices this DTH supports). The IDE should make the line red to indicate that its commented out. Click -Save-. Then click -Publish-, -For Me-. That will save and publish the driver to your cloud. Now your existing devices will continue to work but new devices will no longer find the DTH.
Well thanks to you I finally found the fingerprint line and followed the procedure you provided. I will now remove and delete the device and hopefully, the new Edge drivers will load.
I have now migrated all my Zooz devices over to the supplied edge drivers and reinstalled them. They all show “placeholder” in the IDE and in the app they show “driver” now. I have not yet deleted my customized DTH after commenting out the fingerprint but will do this over the weekend. However I noticed in the IDE under devices they are all still showing under execution as “cloud”. Is that correct? I thought they would now be local but really do not understand. Thanks.
That is correct. IDE was designed for groovy and therefore it does not show the Edge devices data so you will basically only see Placeholder and Cloud. It does run locally though
Thanks. Would not have thought of that because I really don’t see any faster execution of my automations but speed was never an issue with custom DH and cloud. One strange thing though is when I finally deleted all my custom DH in the IDE the affected devices started acting strangely with the automation and I had to reset some of them. I think they are all working ok now but will need to wait and see on some of them.
