Anyone know the status of Ecobee in post-Groovy ST?
It looks like I have a couple custom device handlers and the Ecobee Connect app. Do these need to be updated to something else?
Correct, those are custom groovy smartapps and Will no longer work once the transition is complete.
There is an official integration that you can use, and it should continue to work fine, but it does have somewhat fewer features.
It also seems likely that there will eventually be a matter integration once both companies fully support that, but it’s not clear whether that will have more or less features.
Hey…THANKS!
I added via your instructions above. IDE still shows the same device types as my previous screenshot. Is that expected?
you probably need to unpublish your custom ecobee smartapp
hmm… i already deleted it (the dh’s and app) from the IDE
More discussion:
