I have 3 TRV’s from Devolo lookalike of Danfoss Living Connect.
When I open the tile of a TRV, there is a temperature scale. When pressing the graph button on the upper rh corner in the scale the tile closes instead of showing the temp graph.
Happens with all 3 TRV’s after the update of the app. (2019/12 Android)
Might be related to the following issue. Please report the issue to ST support. Click on the menu (three bars in the upper left of the screen on the main page) and click Help.
I meant change it to English (United States) or English (United Kingdom). Is it what you set up? The App’s and the phone’s default language has to be English.
I have the same issue. Power consumption histograms never load and force close the app. Deleting and repairing the devices again do nothing. Sometimes they load and sometimes they don’t, but never have energy consumption AND power consumption histograms both loaded. If I’m lucky one will load for the day but not the month.
@Brad_ST, has this issue with the graphs developed further to the English versions too? Can you see the same think with the power consumption?
Is there any ETA when will this be fixed?
Some devices has picked up the new UX, some didn’t. Those with defined vid, they did.
When I look at the ST Motion sensor, that reports temperature, I can see the bars, but with other devices I can see only a single one. It might be something else in the background, how the events are stored.
I can confirm this behavior… ST water leak sensor (temperature) shows histogram OK with multiple values but 2 pcs Xiaomi Aqara temperature pressure sensors only one value (using Custom DTH from bspranger)
Previous language related histogram crash/app restart seems to be fixed
