Let’s try something, here’s two statements:
“The failure rate, and for the exact same reason every time is unusually high.”
“The failure rate, and for the exact same reason every time is unusually high, this is 100% fact and true so don’t even try and dispute it”
Which of the two statements is “as though it were fact”? Yes, it DOES require the explicit use of some definitive word like “fact” to change my sentence from just a mere internet claim (based on my experience/research) into an indisputable statement.
My claim was that the failure rate was unusually high, I didn’t ALSO claim at the same time that I am 100% correct. Do you understand the difference?
Dan Parker Pedant Mode On: I didn’t explicitly say that everything you have said is misrepresenting everything I have said, what follows from that statement is merely a clarification of what I was trying to express just in case it was being misrepresented through misunderstanding what I am saying.
Man, I like using your needless pedantic aggression against yourself.
Are you able to disprove the other way? Are you able to disprove that it WON’T fail after a long enough time? Because your assertion is that I cannot claim that it will fail after long enough, meaning that you can disprove my claim and that it won’t fail after long enough.
And that’s the final little nugget, fortunately for me, we’re not friends or related, which means you haven’t the foggiest idea what I do and don’t know factually.
I do love your need to be Internet’s police on what’s correct and what isn’t, I see you getting aggravated all over various Facebook groups and on here. It must be tiring, I used to be as angry as you and felt the need to “set everyone straight!” but then I realised I was just being an angry little man and causing myself unnecessary stress over pointless Internet posts. I recommend you re-evaluate some life choices and perhaps don’t take everything so black and white, allow a little forgiveness and wiggle room and you’ll find yourself being a much nicer person to everyone else who will in turn respond to you in kind much better.
Anyway, I KNOW you’ll need to have the last say in this so say your piece and this will be the last I speak to you specifically on this.
Back to the point.
Good plan, don’t forget the Lowe’s coupon codes to get it even cheaper than that! Would you mind doing me a favour and letting me know what hardware/software rev it’s installed with when you get it? I want to know if there has been changes since mine which hasn’t failed yet but it does randomly lock up and become completely unresponsive, I have to power cycle it to get it to start responding again, it’s the only device in my Z-Wave mesh that I’ve had behave this way.
