GE Switches and Outlets failing
I have a Smartthings system on a V2 hub with 50+ (hardware) devices, including about 40 ZWave switches and outlets. Over the past 3 years, 10-12 GE switches and 3-5 GE outlets have failed and had to be replaced. As near as I can tell, all the devices stopped working when the relay failed (blue light flashing - resetting doesn’t help).
The problem is bad enough that I now keep an inventory of replacements on the shelf.
What’s particularly frustrating is that they seem to be particularly prone to failure right when I turn a circuit back on after replacing a failed switch. It happened today. I cut the power and replaced a failed GE switch in a bank of three with an iNovelli unit. As soon as I reset the circuit breaker, an adjacent GE switch failed. I gave up and replaced the second failed one and the third one (which hadn’t failed) just so that I wouldn’t have to come back to it.
I have begun to replace the GE switches with iNovelli switches (8 so far), hoping that the reliability will be better. I haven’t had the iNovelli ones long enough to tell if they will last longer yet, but I do like the firmware better and the setup is much easier.
Unfortunately, there are no iNovelli outlets, so for now I am stuck with the unreliable GE Enbrighten ones. I replaced one of those today.
Anyone have similar problems? Ideas?
It is a known problem with the older Jasco devices. They will replace them for free if they are less than 5 years old. Call there customer service.
I did contact them a couple of times. They did get me replacements, but I got fed up with it. Replacing electrical switches is becoming a regular weekend activity. I need a device I can put in the wall and have it work for several years.
yup, known to fail. your best bet is to go with another brand.
For outlets, probably better to use pocket sockets. You have a wider variety to choose from and if one does fail, you just unplug it and swap.
You’re right, and I use pluggable outlets several places, primarily because I like to be able to move them around easily. For the rest, though, I like the clean look of an in-wall outlet.
yup, this is what we do and when i help other people set up.
I wish I knew this before I threw them away and bought Meross, wifi outlets compatible with smartthings. But reading more says it was not the bad idea. GE failed after a power outage. Four of them. Voltage spike?
I had some older non-plus date code of around 2014 last 5 years before I replaced them. Seems the 17XX date codes seem to fail more than others and likely why GE Jasco extended their warranty from 2 to 5 years. I haven’t had any troubles with the newer models. I have over 100 Zwave and Zigbee switches in my home.
Yes. It does appear that vulnerability to a voltage spike is the problem with the GE switches. They seem to fail only when power is restored after a power failure or after resetting a circuit breaker.
