I have setup a couple of GE motion sensors to detect motion and turn on lights, and then when no motion is detected, it will shut the lights off. In ST I have set it up to shut light off 1 minute after no motion is detected. This works great, but it appears the motion sensor itself stays active for 4 minutes after initially detected. Is there any way to get the light to shut off automatically after 1 minute total time?
Unfortunately it doesn’t seem like there is a way to change the default 4 minute timer reset before it detects motion again on this device but you might be able to do what you need with WebCore which has a bit of a learning curve although there’s lots of help available.
