Motion sensor to turn on AND off lights
I’ve made a rule to turn on the kitchen lights when motion is detected. However, I do not see any way within the rule to turn the lights off (if still on) after X minutes of inactivity from that same motion sensor.
Can anyone help with this? Thanks!
@shackrock
What app are you using for this?
Well at this point all I know is the Smartthings App on iOS. Do I have other options? =).
For the record it’s the GE Dimmer Z-Wave switch.
oic, you can do this using the Smart Lights smart app, go to marketplace, smartapps, its located under smartthings recommends
Ah, I didn’t realize there were other apps like this inside of the ST app, that’s great, I’ll give it a shot. Thanks!
make sure you undo the other rule (routine?) you had that was doing this before.
Got it, thanks for the help!
Works like a charm! Thanks again
