I hooked up my Christmas lights to a GE (Jasco) plug that is outside on my porch. I ended up excluding and re-pairing with it. For some reason though, IDE saw it as a generic switch, so I changed it, but it will not turn on/off with the app. I’m able to manually turn it on by pressing the button on the switch. Anyone know how to reset these or is it just hosed?
I have one of this outlet you are talking about and it’s a mesh issue. You can try z-wave exclusion in the ST app and press the button on the outlet. It did not work for me due to distance so I ended up bringing the hub close to the outlet. Added it back, put the hub back to the original location and do a z-wave mesh repair. If you don’t have another repeater in between the outlet and the hub then it’s not going to work all the time.
Hey Matt. It’s not too far, probably 10 feet, the box is plastic in wood. I might just try putting a different switch in there tonight and see if that fixes it.
