GE 45856 device handler
I am looking for a device handler for the GE 45856, a Zigbee Switch with power and Energy reporting capability. The Smartthing device handler only reports power real time and does not report energy use. I am more interested in energy usage over time. Does anybody know of a custom device handler for this product/purpose or a standard device handler that may work?
I looked into this a few months ago and added some logging to the current device handler. I did not see any energy reporting messages coming back from the switch. I’m no Zigbee expert, though. Jasco does mention on their site that it keeps track of kwh, but idk.
Tagging along.
If anyone is interested, here’s some parse raw descriptions that I logged for the last 10 minutes. Cluster 0702 is for power/energy monitoring, but I only ever see watt data, not kwh data.
46a68285-c5db-440b-8c7f-4b008b63dcb4 2:40:36 PM: debug description is read attr - raw: 88050107020C00042A000000, dni: 8805, endpoint: 01, cluster: 0702, size: 12, attrId: 0400, result: success, encoding: 2a, value: 000000
46a68285-c5db-440b-8c7f-4b008b63dcb4 2:40:35 PM: debug description is on/off: 0
46a68285-c5db-440b-8c7f-4b008b63dcb4 2:35:35 PM: debug description is on/off: 0
46a68285-c5db-440b-8c7f-4b008b63dcb4 2:30:36 PM: debug description is read attr - raw: 88050107020C00042A000000, dni: 8805, endpoint: 01, cluster: 0702, size: 12, attrId: 0400, result: success, encoding: 2a, value: 000000
46a68285-c5db-440b-8c7f-4b008b63dcb4 2:30:35 PM: debug description is on/off: 0
46a68285-c5db-440b-8c7f-4b008b63dcb4 2:30:35 PM: debug description is catchall: 0104 0006 01 01 0000 00 8805 00 00 0000 0B 01 0000
46a68285-c5db-440b-8c7f-4b008b63dcb4 2:30:35 PM: debug description is read attr - raw: 88050107020C00042A140100, dni: 8805, endpoint: 01, cluster: 0702, size: 12, attrId: 0400, result: success, encoding: 2a, value: 000114
46a68285-c5db-440b-8c7f-4b008b63dcb4 2:30:22 PM: debug description is read attr - raw: 88050107020C00042A8D0100, dni: 8805, endpoint: 01, cluster: 0702, size: 12, attrId: 0400, result: success, encoding: 2a, value: 00018d
46a68285-c5db-440b-8c7f-4b008b63dcb4 2:30:14 PM: debug description is read attr - raw: 88050107020C00042A920100, dni: 8805, endpoint: 01, cluster: 0702, size: 12, attrId: 0400, result: success, encoding: 2a, value: 000192
46a68285-c5db-440b-8c7f-4b008b63dcb4 2:30:13 PM: debug description is read attr - raw: 88050107020C00042A390100, dni: 8805, endpoint: 01, cluster: 0702, size: 12, attrId: 0400, result: success, encoding: 2a, value: 000139
46a68285-c5db-440b-8c7f-4b008b63dcb4 2:30:12 PM: debug description is on/off: 1
46a68285-c5db-440b-8c7f-4b008b63dcb4 2:30:12 PM: debug description is catchall: 0104 0006 01 01 0000 00 8805 00 00 0000 0B 01 0100
