I’m confused by this question. Do you mean the same power supply? Or same electrical outlet set?
Also if you haven’t you should browse this thread.
Yes you can do it. If your careful and make some edits to your DTH you could possibly go up to 3. It was discussed in the thread above.
You can get a larger transformer, but again you’ll have to be careful as you could and probably would be overloading the control amp by having too many lights on it.
That will also require you to make some of your own connections up to use something else. It won’t just plug in like it does now. Not hard just something to be aware of.
I believe that is also so discussed in that thread, or others I have read.
