Has anyone used FortrezZ wwa02aa? Does it work with ST? Anything special that needs to be done?
If you read a bit more on the link you provided, you’ll see your question is answered in the customer question section.
It’s also listed here:
$48 each at Amazon - That’s nuts.
When I put in bottom of the fridge, it would infrequently signal wet - something about the cold confused it. No condensation was present. The Smartsense / PEQ sensors work in the fridge without trouble.
