Has anyone compared the Fortrezz and new SmartThings Moisture Sensors? It seems they are the same price, but the Fortrezz includes the Temperature Sensor and the SmartThings unit does not. I also like the fact that the Fortrezz uses regular AA batteries.
Also, there is a note that the SmartThings can be used to trigger a Siren; is there a recommended Siren Module to make this work?
They Do Not do temperature, but they are very easy to add to SmartThings. They immediately fire off a notification if you touch them with a wet towel, so I’m assuming they’ll do well if the real deal occurs.
Thank you @urman, the temperature component is worth it to me for the extra money. It seems then that the only difference in the two units is appearance and battery type.
My unit seems to only report two battery levels within the first day I insert the batteries. Some have this issue and other don’t. I never contacted the manufacturer over the issue.
When I pop out the batteries and check them I have over 80% after six months. Go figure.
Monitoring battery level has been a pet peeve of mine, so this device isn’t significantly different than others on that front.
Anyone having issues with Fortezz battery reporting? I got 90% one day, down to 1% three days later. It’s a pain to get to but I’ll try pulling out batteries and reinserting this weekend.
2014-11-26 4:06:12.686 AM PST
1 day ago DEVICE battery 1 Crawlspace Moisture Sensor has a low battery
2014-11-23 5:53:12.096 AM PST
4 days ago DEVICE battery 90 Crawlspace Moisture Sensor battery is 90%
2014-11-11 2:52:22.777 AM PST
2 weeks ago DEVICE battery 91 Crawlspace Moisture Sensor battery is 91%
2014-11-07 1:49:04.496 AM PST
3 weeks ago DEVICE battery 92 Crawlspace Moisture Sensor battery is 92%
