First Alert Z-Wave Plus Smoke / CO Combo Alarm is added as a contact?
This is what I’ve bought.
After I added it to smartthings, it used Z-wave Masquweade v1.01 driver and was set as a contact sensor. I can manually change to either smoke or CO sensor but there is no combo sensor option.
I changed to other deivers “Z-wave associator” or “Z-Wave Switch” and both were not working.
I saw someone said I should pair next to the hub to get the correct fingerprint. I removed it and repaired near by the hub, but still got the same issue as a contact sensor with driver Z-wave Masquweade v1.0. Any help? Thank you
Please post the a screenshot of the device details section from the ST Advanced Web App.
Are you using the Z-Wave Masquerade driver for other devices?
Thank you, the following is the screenshot and yes I do use Z-Wave Masquerade for other devices.
Also how can I tell if a driver is currently used without knowing the specific device which is from a large group of devices?
Hmmm. That fingerprint exists in the stock Z-Wave smoke detector driver:
  - id: 0138/0001/0003
    deviceLabel: First Alert Smoke Detector
    manufacturerId: 0x0138
    productType: 0x0001
    productId: 0x0003
    deviceProfileName: smoke-co-battery
Normally, I would expect that to override matching on the generic command classes that happens in the masquerade driver. However, since the point of the masquerade driver is to allow a device to act as something else, I wonder if that is coming into play?
I suspect the easiest way to do handle this would be to install the stock driver from the beta channel so that you can select it via the mobile app/AWA/CLI for your smoke detector.
ST Beta Drivers Channel
You should try @Mariano_Colmenarejo 's “Z-Wave Smoke alarm-Mc” driver. It works with mine.
Yes, that would also give him the option to select a different driver which can’t be done currently since the stock drivers are not listed when changing drivers.
Thank you all @h0ckeysk8er amd @Paul_Oliver . I am using @Mariano_Colmenarejo 's “Z-Wave Smoke alarm-Mc” driver and it has resolved the issue. Thanks again!
Hi, I’m fairly new to SmartThings trying to find this driver and can’t seem to find an invitation link. Can you help?
This is the link
