Firmware update Wednesday
From support:
Aaron sent me a copy also. Here is a text version:
Update notes for the 13.5 release:
  1. Enhanced Cloud Link Security
  2. All server communication now uses the binary protocol. This improves efficiency and lowers bandwidth use.
  3. Support for generically reading ZigBee client attributes
  4. Added real time with timezone, based on the Location so the hub can provide the ZigBee time cluster
  5. Fixed bug that continued to poll Z-Wave switches after they were deleted
  6. Fixed bug that caused some battery powered devices to be over-polled
  7. Fixed bug that interfered with adding Z-Wave devices with long command support lists
  8. Added Z-Wave ā€œreplace failed deviceā€ feature
  9. Improved reliability of Z-Wave network repair
My favorite change I think is the ā€œreplaced failed deviceā€ feature.
Ability to replace a device without removing the devoce completey from STs? No more removing tons of rules and then adding all of them back? I hope so!
Saw that too and hope that your interpretation is right. I would think it would require more than a firmware update, however, so it might not work until an app or IDE update.
I think #4 allows Orbit water timer pairing.
I agree.
[quote="@ beckwith
  • I think this is the first ā€œofficialā€ firmware update since 11.00603.
    Otherwise, support would load 000.011.00705 to fix known issues upon
    request.
    [/quote]
So are you saying that I don’t need the update and will not get it?
Yikes! That’s my fault. Forgot to include the time zone in the email blast for today.
It’s EST.
@joelw135
Everyone is getting this firmware update from what I can tell. It just will be rolled out over time.
Correct. Staged roll out. Everyone will get the update.
Looks like my firmware update has already started but failed. I happened to be checking the logs for a different reason and this came across:
62d0734c-e095-491b-91b5-dc6071812a0d 10:07:24 AM: trace cp desc: firmware update started
62d0734c-e095-491b-91b5-dc6071812a0d 10:07:10 AM: trace cp desc: Firmware update failed
62d0734c-e095-491b-91b5-dc6071812a0d 10:07:10 AM: trace cp desc: hub has disconnected
62d0734c-e095-491b-91b5-dc6071812a0d 10:06:59 AM: trace cp desc: hardwareID:0001, version:02, {deleted…}, zigbeeFWMajor:1, zigbeeFWMinor:5, zigbeeFWBuild:4, zigbeePanID:BA9A, zigbeeNodeID:0000, zigbeePowerLevel:254, zigbeeChannel:14, zwaveVersion:0, zwaveSerialVersion:0, zwaveHomeID:D7111F34, zwaveNodeID:01, zwavePowerLevel:00, zwaveRegion:255, bootloaderVersion:4
62d0734c-e095-491b-91b5-dc6071812a0d 10:06:54 AM: trace cp desc: Firmware download started
Interesting… I got it too. But mine completed and I am on the following
000.013.00005
zigbeeFirmware: 1.5.4
zwaveVersion: 809
2015-01-14 9:39:21.488 AM CST
36 minutes ago HUB firmwareSuccess 1.0 Firmware update complete
2015-01-14 9:38:26.683 AM CST
37 minutes ago HUB firmwareRebooting 0.0 Firmware downloaded completed and rebooting hub
2015-01-14 9:38:26.666 AM CST
37 minutes ago HUB firmwareDownloading 1.0 Firmware download in progress
My feature request finally made it in! Nice… Of course, it was really needed to be able to swap to a new hub…since I’m guessing the code base to replace a failed device is similar to what will do the migration?
yep. i would also assume the same thing
Can somebody explain this part to me, please? Willing to learn. :slight_smile: Is it like providing the current time so that other devices on the network can synchronize to a common time value???
Eric, I have the same
It is explained here:
OK, so I couldn’t wait for a response from support why my firmware failed so I tried recycling the power on my hub in hopes that it would try again. Now I get the following:
e8af73f1-3d38-4e00-b3a2-f52fdaca0edf 11:28:00 AM: trace cp desc: firmware update ember version: 01.05.0004
e8af73f1-3d38-4e00-b3a2-f52fdaca0edf 11:27:59 AM: trace cp desc: register
e8af73f1-3d38-4e00-b3a2-f52fdaca0edf 11:27:59 AM: trace cp desc: stack status: 90
e8af73f1-3d38-4e00-b3a2-f52fdaca0edf 11:26:22 AM: trace cp desc: firmware update main failed
e8af73f1-3d38-4e00-b3a2-f52fdaca0edf 11:26:22 AM: trace cp desc: hub has disconnected
So it looks like it is failed and isn’t going to try again until something gives it a push.
Others see a firmware attempt succeed or fail?
Mine was successful 1
:smile:
2 success and 1 failure so far.
