Ok so the default is that it wont report lux until lux changes by 200lux…try shining a light directly at the one that isn’t reporting…see what happens in the log
likewise i have updated the code, this should now work for inactive…if the tile doesn’t update please forward the logs again…failing this if someone is up for a remote session by Teamviewer or even Screensharing over skype we could speed this process up tenfold try this latest code and PM me if you want to go down this route
Well considering we only communicated via the forum, i thought 5 hours wasn’t too bad considering…would probably have taken an hour if i had a device in hand…it could have been far far worse
Excellent updates to this thread - I have yet to figure out how to install custom code but I am going to give it a try now seen as though you went to all this trouble its the least I can do!!!
Copy it and then paste it in IDE. Go to IDE. Select My device handlers, select create new device handler. Select the tab to copy and paste code. Past the code over and save. Publish to me.
Now go over to my devices. Edit the device in question. In this case the motion sensor possibly listed as smoke detector and change the device handler to the new one you just created. Save and your golden.
I get the following error
Org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: script14570353226281230873782.groovy: 75: expecting ‘}’, found ‘:’ @ line 75, column 32. 75 fingerprint deviceId: “0x0701”, inClusters: “0x5E,0x20,0x86,0x72,0x5A,0x59,0x85,0x73,0x84,0x80,0x71,0x56,0x70,0x31,0x8E,0x22,0x30,0x9C,0x98,0x7A” ^ 1 error
No its not. Just making sure. Someone will be able to help. Just have to wait. Im fairly novice myself. At least we can get them working now which is great!
