Hi everyone!
I am a proud owner of an Samsung smart things hub. So far everything has worked just fine, bit when I try to add Fibaro Motion sensors (not z.wave plus) I only get the motion to work. No reading och temp, lux or anything else but the motion.
Any ideas what could be wrong?
I live i Sweden but the hub is from UK.
Thanks in advance!
//Nick
vikas
September 3, 2017, 9:07pm
2
Hi Nick,
The issue is that the standard DTH does not use the full features available.
Please install [RELEASE] Fibaro Motion Sensor ZW5 (ver. 3.2) (Advanced DTH)
Once done, please change the device type manually from IDE.
I have 4 of these sensors and they work great.
Regards,
Vikas
Hi! I will try it and get back to you! Best Regards Niclas
via Newton Mail
[https://cloudmagic.com/k/d/mailapp?ct=dw&cv=9.8.195&pv=10.0&source=email_footer_2 ]
On Sun, Sep 03, 2017 at 11:17pm, vikas < smartthings@discoursemail.com
[smartthings@discoursemail.com] > wrote: vikas
[https://community.smartthings.com/u/vikas ]
September 3
Hi Nick,
available.
[[RELEASE] Fibaro Motion Sensor ZW5 (ver. 3.2) (Advanced DTH) ]
Regards,
Vikas
Visit Topic
[Fibaro Motion Sensor problem ]
or reply to this email to respond.
To unsubscribe from these emails, click here
[https://community.smartthings.com/email/unsubscribe/c5ea37fc991682a560d41a0d6e963a02d046eb1627bacb5928a12b24fe09d9f2 ]
Hi again,
How to do: " change the device type manually from IDE" Regards Niclas
via Newton Mail
On Sun, Sep 03, 2017 at 11:23pm, nmantinieks@gmail.com <
nmantinieks@gmail.com [nmantinieks@gmail.com] > wrote: Hi! I will try it
via Newton Mail
September 3
Hi Nick,
available.
Regards,
Vikas
Visit Topic
Hi! I cant get it to work, If I use the setting Fibaro motion sensor zw5 it stops working, even the motion stops working.
If I use the standard Fibaro Motion sensor I can get motion to work, an I also get Vibration reading, but no other readings.
Regards Nick
via Newton Mail [https://cloudmagic.com/k/d/mailapp?ct=dw&cv=9.8.195&pv=10.0&source=email_footer_2 ]
On Mon, Sep 04, 2017 at 12:53pm, Niclas Mantinieks < nmantinieks@gmail.com [nmantinieks@gmail.com] > wrote:Ok i Will try tonight
Regards
Nick
vikas
September 4, 2017, 9:02pm
8
Can you try to wake up the device by pressing the wake button and see if that works?
If not, try reset and removing the sensor and adding it again. Refer to fibaro manual on how to do so. When you add again, ideally it would pick up the new dth.
Hi!
Wich setting shoud I use? i have the standard version, not Zwave plus.
Regard
Nick
vikas
September 6, 2017, 9:53am
10
Hi Nick,
Do you mean you dont have the Fibaro Gen5 ZW5 motion sensor?
The standard setting in the device type handler that you installed work fine.
No, I do not have the Gen5 sensor, I have the first generation.
Regards
Nick
Hi again!
New strange problem, suddenly the temp, battery and lux metering is working but the motion does not react.
Strange… any ideas?
vikas
September 7, 2017, 3:38pm
13
Move it closer to the hub and try pushing the wake button once. Maybe its a range issue.
I will try, but they are about 1m from the bub from the start… It must be something else.
Still not working, maybe there are to old?
