This is an advanced DTH for Fibaro Motion Sensor Z-Wave Plus (also known as ZW5) version (firmware 3.2)
This DTH provides not only standard functionality like:
- Motion detection
- Tamper detection
- Temperature measurement
- Light intensity measurement
- Battery readout
But also additionality offers:
- Advanced parameter configuration for 24 parameters
- Readout for the “Earth Quake” detection function (depending on parameter configuration)
- Readout for sensor orientation (depending on parameter configuration)
- Implemented Three Axis capability (depending on parameter configuration)
- Automatic parameter synchronization on manual or periodic wake up.
Avaible parameters are (I’ve purposefully skipped parameter nr 3 since manufacturer doesn’t recomment changing it and parameters related to associations as SmartThings does not support associations):
- Wake Up interval
- Motion Detection Settings:
- Sensitivity
- Blind time
- Time window
- Alarm cancellation delay
- Operating mode
- Night/day
- Tamper Alarm Settings:
- Sensitivity
- Operating mode
- Illuminance Reporting Settings:
- Reporting threshold
- Reporting interval
- Temperature Reporting Settings:
- Measuring interval
- Reporting Interval
- Temperature offset
- Led Indicator Settings:
- Signalling mode
- Brightness
- Illuminance for low indicator brightness
- Illuminance for high indicator brightness
- Temperature for blue colour
- Temperature for red colour
- Tamper alarm
For details on how parameters work if not self explanatory refer to manual for the device: Motion Sensor | FIBARO Manuals
[UPDATE] 2017-04-30:
- Fixed bug that could cause sending a command that should be using Secure Encapsulation without it resulting in the device ignoring the command.
(This bug didn’t affect this DTH but I’m including the fix just in case)
Pictures:
Source Link:
