Fibaro double switch 2 Fgs-223
Not sure if this is the correct section to post in. I have 2018 hub.
Problem is that I have some fibaro double switch 2’s connected with momentary switches, when I press the switch relevent switch S1 or S2, If I hold the switch in for any more length of time than just a quick tap the light connected to the device will switch off as soon as I release the switch.
I have parameter 20 set to momentary switch.
All works good when controlling from the app. It is only when using the local switches I have the issue.
Anyone know if I can adjust any parameters to change this?
Did you find a solution
a few years later came up in search - I think this is how its supposed to work. that how its working at my place too… there’s proper timing involved
