Hello all,
Ive had a good hunt around and i cant find the answer to my question and im eager to know the correct answer incase i make a great expensive mistake with my next purchase . . .
Within the next week i plan to smarten every room in my apartments main lighting on top of all the nice mood lighting ive already done with hue products and fls ballasts + rgbw strips
Due to having very shallow back boxes on my switches and various other reasons and options ive dismissed, ive decided to go for Fibaro Dimmer Modules ABOVE my light fittings in the ceiling and Momentary Switches on the walls as my solution (uk 2wire install) as a pose to having them behind the switches.
Now i have a few questions id like to ask before i jump in and attack this and potentially make any mistakes.
1.) what is the actual difference between the Fibaro Dimmer Modules 1 & 2, as the price point is still fairly identical on these in the UK?
2.) when installing the dimmer module above a light fitting as a pose to behind a switch, does module 1 or 2 suit the situation better or are they theoretically the same as one another in terms of install?
(I only ask this as i have a feeling i read somewhere not to use dimmer 2 modules above light fittings for some reason, however i may be wrong)
3.) the physical momentary switch, as well as turning on and off the lights on that curcuit, can this also dim the lights and would i be right to asume that this is done by holding the switch down for a period of time by which i assume the lights would raise and lower for the period its held down etc
4.) is there an approved device type for both modules yet or is 2 still awaiting this, if not is the community one fully working in a way everyone is happy for any users already using this.
Cheers in advance for the answers its most appreciated and hopefully helps anyone else a little unsure to the finer details of this.
Kyle
