In the command prompt when typing the folder location I get an error saying “command” is not recognized as an internal or external command, operable program or batch file.
I’ve done the usual searches and tried the solutions but still getting the message
Can anyone help please
cjcharles
(cjcharles)
January 29, 2018, 3:55pm
#3
Can I suggest you post in this thread as there are more people there to help out.
I imagine you are not in the right directory when you are trying to use ESPEasy, or the firmware is not in the right folder.
[image]
2017_10_04 Update: If the flashing method in this first post does not work for your device, try the method mentioned in this post:
2017_05_10 Update: Sonoff Dual - Firmware and device handler and child device handler . Flashing info here . Sonoff 4CH - Firmware and device handler and child device handler .
2017_01_21 Update: Release of firmware and SmartApp updates for the Sonoff Touch and Sonoff S20 . Picture for flashing Sonoff Touch in this post .
2016_10_14 Update: I have been playing with the Sonoff TH (16 Amp Version) and am finished with a SmartThings capable firmware for it. This device has a 10 & 16 Amp version and support for a temperature sensor attachment. The device handler supports both temperature and humidity. Here is the firmware & here is the device handler . Y…
