Apparently this used to have full functionality using a device handler by @DrZWave but I don’t see that code anymore.
Does anyone have this working?
I have it working, there is a device handler listed as EZ Multi Pli in the IDE. It’s not as good as the old device handler and it is cloud based but it works.
What was better about the old DTH?
You need to log into the smartthings / samsung account then go to devices and edit that device then you can change the device type.
It works just like the old DTH I just never can get the temperature settings just right.
Ok, I found it. Thanks!
