I am using the new app. I have a few of the smartthings multi-purpose sensors that i want to use for temp only.
The tile on the new app shows status (i.e. open/closed). I’d like to change the tile to show temp.
I modified a device handler but it did not affect the new app.
I did change the device handler to smartsense temp/humidity and that shows temp … but the battery reading is then wrong.
Any suggestions as to what I can change or use to get a temp reading and a correct battery reading.
This is all for the new app … I do not want to load or use Classic.
Nothing new here? Got a Samsung motion sensor with temperature and a Philio Zwave 3in1 with temperature and would like any of them duplicated but showing only temperature. Weird if I have to buy a separate temp sensor. New to Smartthings so not really know what I’m doing with these DTHs. Tried creating a new with same zigbee id but unique network id, type Temperature sensor, but it shows zero.
