@nayelyz
I’m trying to run logcat and keep getting this error
Error: Connection to XXX.XXX.X.XXX:9495 timed out. Ensure hub address is correct and try again
I have verified my IP address both on my router and in the IDE. I even tried rebooting the hub.
nayelyz
(SmartThings Developer Support)
September 8, 2022, 12:57am
2
Can you check if you can make a telnet connection with the Hub, please?
The command is: telnet 192.168.1.107 9495
Here are some instructions to enable the Telnet command in different OS.
Windows
The successful connection message scrolls by quickly and you are presented with a blinking cursor on a blank screen. (You can press Enter to return to the command prompt.)
I don’t know what is supposed to happen but I got the blinking cursor on the black screren
andresg
(andresg)
September 8, 2022, 8:45pm
5
Hi, @Terri_Baker
I am Andres, a member of the Developer Support team.
That is weird. I need to ask you to run the logcat again but this time as it is specified here :
$ SMARTTHINGS_DEBUG=true smartthings <command>
This way you will be running the same command but collecting logs, and then please share those logs.
Hi @andresg
Forgive me but I’m new to CLI so I don’t think I’m doing this correct.
I am running CLI
VERSION
@smartthings/cli/0.0.0-pre.31 win32-x64 node-v12.18.1
I type
smartthings.exe
then
$ SMARTTHINGS_DEBUG=true smartthings edge:drivers:logcat
I get this response
'$' is not recognized as an internal or external command,
operable program or batch file.
andresg
(andresg)
September 9, 2022, 11:13pm
7
Hi, @Terri_Baker
Sorry, I think that work for Linux. Try this. First execute this command:
set SMARTTHINGS_DEBUG=true
then, execute
As far as I am concerned this should be throwing some logs, please share them here.
I was able to get logcat running by updating the cli
andresg
(andresg)
September 12, 2022, 1:43pm
9
Excellent news @Terri_Baker !
