Egde Driver Builder - Oops Internal Server Error
Hi!
Anybody else got this problem with the while accessing the SmartThings Developer website using the https://developer.smartthings.com/ url ? I get this Oops Internal Server Error in trying to access the Edge Driver Builder tool, the steps to get there are below. Tried multiple browsers, different computers, same behaviour.
Hi, @ellie
I couldn’t replicate the issue but let me ask the engineering team to get more info about what’s going on.
@ellie, following up, could you provide the following information, please?
  3. Select Menu (â‹®) and choose Settings
  1. Replicate the issue, take note of the time of the attempt and share it with us including the timezone, for example: 09:05 GMT-6.
    This is to find the event’s logs and see why it failed.
Hello @nayelyz
Contacting you in private
Hi, @ellie
The engineering team was able to find the root cause, it is due to the number of devices in your account. They’ll work on a fix so that’s not a problem anymore. Do you have a device that doesn’t have an official driver match when you pair it to the Hub?
Hello again @nayelyz
Yes I have been having issues with pairing zigbee devices recently, one of them shows as a Zigbee Thing under one of my hub labeled 174, device id 332572c0-5b94-4de9-b9f2-67e7fafd3357
I thought this had to do with fingerprints missing from a community driver. Could it be related to the same issue ?
I see it’s using the Community driver from @Mariano_Colmenarejo called Zigbee Thing Mc, Do you have another custom driver installed for it but it still doesn’t connect to it?
If so, did you verify that the driver contains the device’s fingerprint? I think you can see that info in the device’s detail view of the current Zigbee Thing device using Mariano’s driver.
The issue shouldn’t be related to it because they are different services, we would need to validate the info above first.
hello again @nayelyz
Indeed the device was installed using a community driver which I have a hard time pairing… I will have to try it again since the fingerprints were added recently.
As for my other devices, I have tons of them and pertaining to your question: “Do you have a device that doesn’t have an official driver match when you pair it to the Hub?”
The answer is the same device id 332572c0-5b94-4de9-b9f2-67e7fafd3357 was initially installed not linked to that custom driver from Mariano, so it was unable to pair, from there I decided to try building my own customer edge driver for it, that’s when the Oops Internal server error occured.
Ok, I was asking to suggest you check a custom driver already published in the Community or develop your driver based on one of the existing ones from SmartThings (whose code you can find here). And, I can help you with it.
This is because there’s no ETA about when this could be solved and this would allow you to continue with your process.
Hello @nayelyz
Hope this message finds you well, I was curious to know if there was any progress on my request? I tried once more yesterday and I still get the error, crossing my fingers the engineering took some time to look into the issue
Alternatively, if they have no solution yet, is there a work around available so I can still develop a driver and be able to test it ?
Thanks for your kind help
Hi, @ellie
The engineering team is still working on this but this happens due to the amount of devices you have, if you want to use the tool, you would need to use another account that has fewer devices installed.
Hi, @ellie
The engineering team mentioned this should be fixed, please let us know if you can use the tool successfully.
Good day @nayelyz
Very happy :slight_smile: it works like a charm !
Thanks for your return on this issue and I was able to fix a driver problem I had as a result
Awesome! I’ll let the team know, I’m happy you fixed the driver.
